01-07-2015, 09:23 PM | #1 |
Drives: 2015 v6 Camaro Join Date: Dec 2014
Parallel Parking
I just bought my Camaro a couple weeks a go and men I cant even park the thing straight. Im afraid to attempt parallel parking. Any tips? I haven't tinted my windows yet to avoid reducing visibility until im confident with the car's dimensions. I used to drive a scion tc btw.
01-07-2015, 09:27 PM | #2 |
Too much is never enough!
It will take some getting used to, but you'll get the hang of it. Our cars make it hard to see curbs on a good day, so even in a perfect world their still a PITA
01-07-2015, 09:27 PM | #3 |
Drives: 50th Anni.. coming home 11/01 Join Date: Jul 2014
Lining it up takes a lil while to get used to... I have 30,000 km on my car since July and its still pleasing when I step out of the car and its parked straight. I should have it down pat by now.
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms. |
01-07-2015, 09:38 PM | #4 |
DOOOOOD!!!!
i've had it for 6 months and haven't even tried!!!
2014 2SS/RS VERT L99 SUMMIT WHITE AIRAID CAI BORLA ATAK CAT-BACK EXHAUST ELITE ENGINEERING CATCH-CAN RANGE AFM-DELETE MODULE HUPER OPTIK 40 CHROME PEDALS PREMIUM FLOOR MATS PREMIUM CARGO MAT DEDICATED 32GB iPHONE HD[/I][/B][IMG][/IMG] |
01-07-2015, 09:40 PM | #5 |
Parallel parking would certainly be easier if you tilt the mirror down. just sayin.
01-08-2015, 01:14 AM | #6 |
Drives: too many Join Date: Jul 2013
Yeah not easy lots practice.. I've turned mirrors down to see the curb..
01-08-2015, 01:22 AM | #7 |
Drives: ( . )( . ) Join Date: Feb 2010
I'm always afraid to curb my rims.
01-08-2015, 02:02 AM | #8 |
American Gold Whisperer
Drives: 2014 White 1LE 2SS/RS/NPP/Rec/Nav Join Date: May 2014
Helpful hints...
Do not parallel park. Instead find some spot wayy in the back. Be sure to take up 3 or 4 spaces. And do not forget the hazard cones around your ride. Most importantly, stay away from ANY store parking lot. In particular, walmart. Seriously though. I have yet to 8have the courage to even try to parallel park. |
01-08-2015, 06:31 AM | #9 |
Drives: 11 Camaro V6 RS, 03 BMW Z4 Join Date: Oct 2013
I live in a very tight city, I know the difficulty of parking all too well. I am not afraid to admit that I usually have a spotter to help me. If I am alone I will adjust my mirrors to see the passenger side better. I will also get out and look around a few times. I don't think there is anyone here who has had to park in a smaller place than I have! Good luck, be slow, check out the corners and don't worry about what others say about being too careful.
01-08-2015, 08:39 AM | #10 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Practice, practice, practice. Once you get it down it's not difficult.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
01-08-2015, 08:42 AM | #11 |
Drives: 2014 Camaro 1SS Join Date: Nov 2014
Three of my wheels are curb rashed to hell from trying to park on streets. One of the cities I live near has basically 90 degree angled curbs, so if you even bump it... scrrrrrratch. Don't do it if you can avoid it.
01-08-2015, 08:50 AM | #12 |
Drives: "Kara Zor-El" 2017 2SS HBM Join Date: Jul 2014
I try not to do it whenever possible but if I have to I try to find a place where there are two or more space open and pull in and line it up that way. Hell, I still have issues with backing into a space in a parking lot, though I have gotten better.
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!! What? Dangerzoooooone. |
01-08-2015, 08:55 AM | #13 |
I actually find it easier to back the Camaro in straight than I do pull forward straight. My car will only fit up my driveway and into my garage in reverse (weird angles), so I've gotten used to it I guess. I also back into the same space every day at work, next to a support wall in the parking garage, as close to the wall as I can get... usually about an inch of clearance on the passenger mirror.
01-08-2015, 10:36 AM | #14 |
Pracitce, you get used to it.
And tilt the curb side mirror down to see the curb in relation to the side of the car, it helps.
Retired United States Army
Bernadette: 2LT/RS, ABM #2041 of 3903 ZL-1 Springs | CAI | Muffler delete | Magnaflow resonator | LED DRL | DRL harness | RX Catch Can | Mini me Cortana: 2015 Harley Davidson Road Glide Special V&H Power Duals Headers & Oversized 450 Raider mufflers | Screamin' Eagle Stage 1 Chisel Extreme intake | Screamin' Eagle Stage 1 programmer | Klock Werks 12" Pro-Touring windscreen Own an Aqua Blue Metallic Camaro? Click here to join us on Facebook and help us in establishing the Aqua Blue Registry to locate all 3903 of these beautiful Camaros! |
