02-20-2012, 10:13 AM | #1 |
Squeaking Dash Fan
2011 Camaro 2SS RS
Is anyone else having a problem with the fan (heater/AC) squeaking while it's spinning? Mine is about to drive me nuts! :( Is it something easy to fix, like an hour or 2 at the dealership or will they balk at having to give me a rental and tear the dash apart to shut it up? Thanks for any help! |
02-20-2012, 11:07 AM | #2 |
Drives: 2010 Camaro 1SS M6, RJT Join Date: Sep 2010
Mine does too. Took it in for warranty and they claimed they couldnt reproduce it. I will have to go back to show them personally, which is a pain, but must be done i guess.
02-20-2012, 11:12 AM | #3 |
Drives: Camaro LS Join Date: Apr 2010
This happens on a lot of GM cars, and the dealers usually won't fix it in my experience.
As a temporary fix, you can turn your fan speed all the way up for a second or two and then back to where you wanted it, which seems to 'reset' the noise for a short while -- at least that works for me. |
02-20-2012, 01:35 PM | #4 |
Drives: GM Vehicles Join Date: Jun 2010
I saw this thread today> http://camaro5.com/forums/showthread...43#post4509243. I thought it might help just in case you're having the same noise. If all else fails you should be able to have this taken care of your dealer. Just show them what you're hearing to make sure they know what to look for and they should be able to take care of it for you.
Jeff Morris, Chevrolet Customer Service |
Similar Threads | ||||
Where to buy dash inserts? | OHIOSS | Cosmetics and Lighting Modification Discussions | 3 | 02-27-2012 04:34 PM |
1st real motorized Ipad Dash Install | Peter | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 49 | 06-07-2011 09:13 PM |
Hot air Intakes -By Kenne bell | ADM PERFORMANCE | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 66 | 02-08-2011 08:33 PM |
List of Intakes that will work with the TVS-2300 MagnaCharger | JJ2010 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 26 | 03-19-2010 02:11 AM |
Factory dash ABL? | bkwagonss | 5th Gen Camaro SS LS LT General Discussions | 3 | 09-17-2009 10:41 AM |
