Old 02-22-2012, 05:03 PM   #1
Medic726
Medic726's Avatar
Drives: 2020 Camaro convertible RS Auto
Need Help..Lifter issue or belt noise??
One says normal, one says belt, I say lifter. This noise happens on startup sometimes for a few seconds, sometimes longer. This was today after about an hours drive on the interstate. Oil level, pressure, temp all normal just this stupid noise is driving me nuts. Been in to the dealer once they said its ok.
Medic726 is offline   Reply With Quote
Old 02-22-2012, 05:08 PM   #2
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
To me I would say lifter epically if it goes away after a couple of seconds. I'm assuming it was cold today in Illinois? Could be caused by a thinner oil and really isn't harmless. I could be wrong though.
Old 02-22-2012, 05:15 PM   #3
Medic726
Medic726's Avatar
around 38 in Illinois where I was at. Local mechanic put a little grease on the belt last month and the noise went away for a week or so.
Old 02-22-2012, 05:17 PM   #4
ron10
Drives: 2010 2SS IOM L99
mine does the same thing and it is the lifters.i have an early build 2010 that had the lifter issues.
Old 02-22-2012, 05:44 PM   #5
Russell James
Russell James's Avatar
I'd get a mechanics stethoscope from an auto parts store, and listen to the valve covers when it is making that noise. You can also clean the pilling out of the belt grooves on the belt and pulley, very carefully with a brush while idling. But, I've not heard a belt make that sound. Sounds like the lifter issue.
You don't want to use any dressing or grease on this type of belt. It can cause the pilling of debris to fill up the grooves.
Old 02-22-2012, 05:49 PM   #6
Sweet Zness
Because I Can
Sweet Zness's Avatar
Drives: 08 IOM G8GT 11 Victory Red SS
My car did the exact same thing. I video'd it also. It turned out being the AC compressor going bad. Replaced by dealership under warranty.
Also your dealership is freaking nuts if they say thats normal or ok. You should tell them to start any other camaro on their lot to see if it makes the same noise.
http://youtu.be/7HToZU00Ckg
Sweet Zness is offline   Reply With Quote
Old 02-22-2012, 06:22 PM   #7
Medic726
Medic726's Avatar
Sweet Zness that video sounds exactly like mine. Gonna mention the ac compressor to the dealership when I talk to them tomorrow.
Old 02-22-2012, 06:44 PM   #8
Sweet Zness
Because I Can
No problem man.
Old 02-29-2012, 06:26 PM   #9
Medic726
Medic726's Avatar
So car went in today for the same issue. I emailed them several videos showing the noise along with the one above. They ended up replacing the AC Compressor and belt. Seems to have resolved the issue but time will tell. Now to deal with the damage they caused to my stripes when the washed it.
Old 02-29-2012, 08:02 PM   #10
Gillespiers
Gillespiers's Avatar
Drives: 2011 2SS/RS Red Jewel
Sounds like a new stripe job is in order !
Gillespiers is offline   Reply With Quote
Old 02-29-2012, 08:21 PM   #11
gorgeous-ss
Drives: 2011 ss/rs
What dealer did you go to. I'm in Illinois too
gorgeous-ss is offline   Reply With Quote
Old 02-29-2012, 08:49 PM   #12
Medic726
Medic726's Avatar
Eriksen in Milan. Probly won't be going back there after this stripe problem.http://www.camaro5.com/forums/showthread.php?t=199362
Clunking/clattering noise when pressing clutch - INFO HERE DarkObsession V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 20 12-30-2016 03:06 AM
L99 Lifter tick carnage.... blackknight 5th Gen Camaro SS LS LT General Discussions 102 04-10-2013 06:16 PM
Need Mechanics Help with Oil Pressure Issue on 1999 3.8 Camaro Solocus 4th Generation Camaros 8 05-06-2011 09:49 AM
OBXR Headers Installed Smoky10 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 44 12-17-2010 11:01 PM
anyone having this issue ? drivers door Damage from seat belt with pictures yesno20102ssblack Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 12 06-25-2009 11:51 AM
