10-04-2020, 12:43 PM | #1 |
Drives: 2011 Chevy Camaro LS Join Date: May 2016
Tape stuck?
How do I remove this tape without damaging the paint of my vehicle?
Or how can I remove it? Window was busted so I had to put tape whenever it rain. Last edited by error3rror; 10-04-2020 at 12:58 PM. |
10-04-2020, 12:57 PM | #2 |
Tri-County Camaro SWFL
What kind of tape? Was it painters tape, electrical tape, masking tape, duct tape? Different tapes have different adhesives. Like painters tape, fairly easy to remove, duct tape good luck
10-04-2020, 12:59 PM | #3 |
Forgot to post a picture.
10-04-2020, 01:06 PM | #4 |
Oh good lord. I suspect it looks worse than it really is.
Start with the weakest stuff possible and work your way up. Personally, I would start with Goo Gone and a lot of clean microfibers. The Goo Gone Spray Gel took all the adhesive residue off from my old cracked and dry vinyl stripes and they were a real mess. They have an automotive grade one that is safer for paints. Do NOT use anything like a Magic Eraser. It will scratch your paint very bad. Once you get the adhesive off you can compound and polish that area if needed. https://googone.com/shop-categories#automotive
10-04-2020, 01:20 PM | #5 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
If you can find it 3M adhesive remover works great.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
10-04-2020, 01:29 PM | #6 |
Drives: 2013 L99 Join Date: Jan 2019
Goo gone or wd40
10-04-2020, 01:42 PM | #7 |
I have never tried that but I do know that 3M makes some absolutely amazing stuff.
10-04-2020, 01:59 PM | #8 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
WD40
10-04-2020, 02:03 PM | #9 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
If I had to guess, his rear window was broken and he covered the opening with some duct tape till he could get the window replaced.
10-04-2020, 02:34 PM | #10 |
Banned
Drives: 2015 Camaro Join Date: Aug 2018
I hope the tape didn't etch into the clearcoat.
10-04-2020, 03:39 PM | #11 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
Let the goo gone or wd40 do the work to not scratch the paint all up , means lots of time to let the goo gone eat the glue before you wipe it off
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
10-04-2020, 03:49 PM | #12 |
Yep. Once the sun starts shining on that tape it can do some weird shit to the clear and/or base coat. My old side stripes were badly cracked. The UV light that shined through the cracks left a copy of the cracked pattern in the paint itself. It was totally smooth to the touch but shadowed right into the paint. Now i have to keep vinyls stripes on the car until I get it resprayed.
First pic is before I removed the nasty stripes the previous owner left on. Second pic is after removal, but before clay bar, and compound. The orange vinyl was actually originally red but was badly faded in that area. The shadowing was covered with matte black side stripes of similar pattern.
10-04-2020, 03:59 PM | #13 |
Drives: 2024Camaro 2SS CE Convertible Join Date: Jul 2013
10-04-2020, 06:00 PM | #14 |
Wow that looks like duct tape or that super sticky clear tape.
Start with a wash, see what you can do with that and clay after. Im sure you will need an adhesive remover. I wouldnt be surprised if that did some funky stuff to the clear coat
