01-19-2016, 02:13 PM | #1 |
Drives: 2013 Camaro 1LS - Ashen Gray Join Date: Jan 2015
dashlogic with plx boost module issue
I got the dashlogic with both the plx wideband and boost modules.. the wideband works fine with the configuration formula.. the boost is not reading properly and see no configuring for it... ive tried analog inputs,map,calculated boost and it wont show boost only vacuum... any info would be appreciated..
"WIDOW" Overkill Edition w/Mace Cams,80mm tb,Jacfab spacer/ported intake,Alky Control,ARH off road pipes,SOLO custom system,3.91 gears, MGW,Phantom grilles,ZL1 appearance pkge, 3dCarbon vents, Lingenfelter hood and spoiler, PLX boost/wideband modules/gauge,ZL1 fuel pump,LF3 hpfp,DSS aluminum driveshaft,JPSS sway bars, Z28 replica wheels and CxRacing coilovers..
01-20-2016, 02:22 PM | #2 |
thanks to camguynj and RedRyder for the help - working fine now!!
01-20-2016, 05:02 PM | #3 |
04-04-2016, 02:07 PM | #4 |
Just curious what the fix was? I'm having the same issue when using map and/or calculated boost, I didn't get the PLX boost module because I thought the factory map could rear boost. Do I need the PLX module for boost?
5.98 @ 115mph
