06-01-2017, 06:03 PM | #1 |
Drives: 2019 Corvette ZR1 Join Date: May 2017
super easy flex fuel install
So... I had some custom fittings made. These are made specifically to facilitate the easiest installation of a flex fuel kit possible. No wrenches, no backing nuts, no fighting with the available space... Just clip and go!
Check out the complete kit here Last edited by DSX Tuning; 07-08-2017 at 07:23 AM. |
06-01-2017, 06:31 PM | #2 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
Great product! Or so it seems, I don't know anything about flex fuel kits haha. However, once I get another daily driver and afford to stand a drop in MPG, I'll definitely look into this and your kit!
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
07-08-2017, 07:07 AM | #3 |
Drives: 2015 2SS/RS/1LE Join Date: Feb 2015
Maybe a dumb question, but would this flex fuel kit work for switching between, say, race gas and regular 91? I currently run, and am tuned for, a 100 octane equivalent Torco/91 mix. I would like to have a way to run straight 91 without having to re-tune every single time...
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports. |
07-08-2017, 07:21 AM | #4 | |
07-17-2017, 05:42 PM | #5 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
i have a question, aside from this kit, what else is needed on completely stock fuel system on a 2010 SS. LS3 with bolt ons only? LT's, CAI, no cats, ported TB. Do i need the ZL1 fuel pump? Do i need injectors?
Bone Stock |
07-17-2017, 07:47 PM | #6 |
Realistically, you're probably fine until you do a cam. Then, you'd just need LSA injectors.
08-21-2017, 07:47 AM | #7 |
Still available and ready to go!
08-21-2017, 09:28 AM | #8 |
Drives: 2011 1ss Join Date: Jun 2017
Interested. Where does this connect to?
For tuning purposes, if you were to switch on Flex fuel, would you be able to run 93 and e85 flex interchangeably without having to constantly reupload a new tune? |
08-21-2017, 10:26 AM | #9 | |
And you are correct... the whole purpose of these sensors is to run 93, ethanol, or any mixture of the two without having to reflash. The tune (when done properly) will automatically adjust. |
08-21-2017, 01:56 PM | #10 |
Great. Will be purchasing this pretty soon!
