12-15-2019, 06:30 PM | #1 |
Drives: 2010 2LT Bumblebee Join Date: Apr 2013
Trunk Release Button Harness for Replacement
So my trunk release button stopped working and a replacement button didn't fix the issue, after checking the wires with a multimeter it seems that the issue is actually the harness that connects to the button. I've circled what I'm talking about in the picture below. I'm having trouble getting a part number for this connector and the person at the Chevy dealership I spoke to over the phone wasn't too helpful. If anyone knows where I can buy this connector it would be a huge help. Thanks
AirLift Air Suspension, Stainless Works Long Tube Headers + Hi-Flo Cats, Resonated X-Pipe, MRT V2 Mufflers, VMAX Ice-olator and Ported Throttle Body, Barton Short Throw Shifter, CAI Intake + Air Scoop
12-16-2019, 02:45 AM | #2 |
You can use a dental tool to pull the pins out of the harness, then replace them.
How did you check them with a Multi Meter? That won't tell you what you need to know anyway. Short the wires and see if the trunk pops, to be SURE it's not the circuit. Take needle-nose pliers, and short both pins inside the harness. The trunk should pop. Or, since you think you need a new harness anyway, strip some insulation off the wires about 2" back, but stagger them, make one higher than the other one. SHORT the two bare spots together, see if it pops. |
12-18-2019, 08:55 PM | #3 | |
12-18-2019, 09:10 PM | #4 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
i wish there was a key slot on the trunk
12-19-2019, 10:15 AM | #5 | |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
