07-25-2020, 03:02 PM | #1 |
Drives: 2010 2LT Bumblebee Join Date: Apr 2013
Very Stiff and Uncomfortable Ride After Installing AirRide
So a couple years ago I installed the new AirRide 3P system. Even after adjusting the dampening, the car is incredibly uncomfortable driving over anything that isn't perfectly flat. Makes a ton of noise to going over any minor imperfections in the road. Before I look into the air suspension, I thought maybe the issue can be the fact that the car's suspension is stock and untouched other than of course the springs being swapped for bags. Not sure if maybe I should first look into upgrading the sway bar, subframe bushings, etc. first and foremost before looking into possible swapping the bags.
Car is a 2010 V6 LT with 80k miles.
AirLift Air Suspension, Stainless Works Long Tube Headers + Hi-Flo Cats, Resonated X-Pipe, MRT V2 Mufflers, VMAX Ice-olator and Ported Throttle Body, Barton Short Throw Shifter, CAI Intake + Air Scoop
07-25-2020, 06:59 PM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
How much are you lowered? Did you time the bushings after lowering? How many miles on the shocks? Before replacing anything I'd jack up the car and start yanking and pulling on the tires and suspension parts to see how much play there is in the bushings and ball joints. How is your alignment?
07-27-2020, 08:04 PM | #3 | |
07-28-2020, 10:28 AM | #4 | |
Drives: 2011 2SS/RS Join Date: Feb 2016
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
07-31-2020, 09:38 AM | #5 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Yeah when you take it in and an alignment ask them to loosen everything and drive it around the parking lot to settle the bushings. Called timing the bushings
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
08-01-2020, 07:15 PM | #6 |
Thanks for all the advice. I found the guide by BMR on how to time the bushings. Even though I'm fairly handy (enough to install the air suspension) I imagine I should have a shop do this since theoretically you can only do this by having the car's weight resting on your suspension as you're re-clocking everything and I'm not sure how to replicate this without jacking up the wheels or buying really tall ramps that allow me to get under the car and access everything.
