07-30-2020, 12:08 AM | #1 |
Drives: 2013 L99 Join Date: Jan 2019
Suspension damage from crash
My son hit a curb at about 70 mph with right wheels causing a lot of damage. Broke the steering knucke, Broke the tie rod, bent control arm, damaged rotor brake line front fender. Shattered both wheels. Tore a hole in the rear caliper. Replacing these items. Waiting for parts.
Does anyone with experience in these matters have suggestions on how to assess the steering rack (electric) other than checking for binding or play once it’s all back together? Anything else I should be checking for? The alignment shop is about 10 miles away. Any way to check alignment and get it close enough not to wear tires excessively on the drive over? |
07-30-2020, 12:21 AM | #2 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
that car needs to be assesed by a chassis/frame expert. i hope ur son is ok and that ur losses are minimal. the truth of the matter is that the damage you see on the outside, has zero to do with what you cant see.
my best advice is to take it to a chassis/frame expert and let them assess it. a 70mph 3800 pound hammer with momentum will flex/bend just about anything. Id make sure that the car is structurally sound before making a decision on replacing anything Sent from my SM-G975U using Tapatalk
Bone Stock |
07-30-2020, 12:23 AM | #3 |
tow the car over if the shop is too far
Bone Stock |
07-30-2020, 05:11 AM | #4 |
Drives: 2011 Camaro 2LT/RS Join Date: May 2015
holy crap! I didn't know those wheels would break like that!
07-30-2020, 07:48 AM | #5 | |
Drives: 2014 1SS/1LE Join Date: Nov 2015
This^^
07-30-2020, 08:37 AM | #6 |
Banned
Drives: 2015 Camaro Join Date: Aug 2018
Are you just trying to get it quickly fixed so you can get rid of it?
I'd at least take it to a frame shop to see if there is any unibody structure damage. |
07-30-2020, 08:40 AM | #7 |
Im going to replace the parts and see if it will align, if not sell it as a salvage car with bent frame. Cant really move it as is. It’s already been salvaged once. I bought it at insurance auction a couple years ago super cheap so didn’t carry any collision/comprehensive. It’s been a great car but I’m not going to mess with a bent frame, not worth it. I was really just hoping to hear from someone with practical, actual experience with this particular vehicle.
07-30-2020, 08:51 AM | #8 |
Banned
I've seen less damage totaled out on Copart. For the safety's sake of the potential buyer who might buy something like that, I'd just part it out.
07-30-2020, 09:15 AM | #9 |
My other objective is allowing the offender the pleasure of fixing the car out in the driveway, sweating, skinning knuckles etc as he reflects on his poor judgement. Just maybe, he’ll understand the consequences. Could have been really bad, but luckily nobody hurt.
07-30-2020, 09:22 AM | #10 |
Drives: 02 Camaro B4C Join Date: Nov 2016
You asked about the electric rack. I have torn up the front suspension on my car. Had my front wheels facing very different directions. Once I replaced the destroyed parts and had the car aligned the rack was fine. They are pretty tough.
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
08-01-2020, 09:37 AM | #11 |
Drives: 2010 Camaro SS Join Date: Aug 2017
If you need some rims just let me know, I have the set off my 2010 that needs new tires but are in great shape. They are Chrome 5 spoke like your 20x8 and 20X9,with tpms sensors in them.
08-01-2020, 09:59 AM | #12 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
08-01-2020, 01:57 PM | #13 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Front cradle damage likely.
08-01-2020, 07:12 PM | #14 |
Drives: 2010 2LT Bumblebee Join Date: Apr 2013
Lmao, I think new rims are the least of his problems here
AirLift Air Suspension, Stainless Works Long Tube Headers + Hi-Flo Cats, Resonated X-Pipe, MRT V2 Mufflers, VMAX Ice-olator and Ported Throttle Body, Barton Short Throw Shifter, CAI Intake + Air Scoop
