06-24-2015, 06:19 PM | #1 |
Drives: 2014 2ss 1le Join Date: Sep 2011
Are the SS and the 1LE suspensions the same?
I used to have a 2011 2SS, and I bought coilovers for it. But then I traded it in for a 2014 2SS 1LE.
Will the coilovers fit my 2014 1LE? |
06-24-2015, 06:30 PM | #2 |
Drives: VW... soon to be a 1LE Join Date: May 2014
Yes
06-24-2015, 09:48 PM | #3 |
Drives: 2013 2SS 1LE NPP GBE Join Date: Sep 2012
I don't think they are the same.
06-24-2015, 11:24 PM | #4 |
Banned
Drives: 2011 Boxster Spyder (best car ever) Join Date: Aug 2014
they are not even close lol...AND leave the 1LE suspension stock, unless you think some company that makes something(coil overs) for every brand of car, has better camaro engineers and deeper pockets than GM.
06-24-2015, 11:59 PM | #5 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
The rear suspension lower control arms were changed in 2012 but that affected mainly the stabilizer bar drop link location. I think your coilovers will work.
The 1LE has the same springs as the SS but different shocks. Also the stabilizer bars and rear toe links are different.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
06-25-2015, 12:30 AM | #6 |
I mainly want it a little bit lower. Would it be better to only install lowered springs instead of coilovers?
06-25-2015, 11:27 PM | #7 |
Banned
if you want it lower, see Justice Pete for the knuckle drop, it is the only way I would do it. I usually will not promote anything unless I KNOW the product, but Pete knows his stuff. He and I disagree on a few things on this board, but I still have no problem recommending him...that should tell you something.
If your budget is $$$$ you could go the Z28 suspension route too.... |
06-26-2015, 02:12 AM | #8 |
Understand the effects on toe, caster and camber when you lower and how this may negatively affect handling. PM @Norcalzl1 or @JusticePete and learn the proper way to do this. Even @OrangeCrush1LE didn't lower the same rate front to back. If not careful and proper you stand to F up that great handling suspension Chevy gave us. Don't just lower. Measure. Analyze. Correct.
-CRT Sent from my iPad using Tapatalk
06-26-2015, 07:40 AM | #9 | |||||
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
Welcome to the 1LE forum where everyone has an opinion! Lets have some fun and break this down a bit for you.
Recommending knuckle drops is slight contradiction to what you stated above regarding leaving the 1LE stock. Does Pete have an engineering degree? Does he have deeper pockets than GM and know more about the Camaro suspension than the Engineers on TEAM Camaro? Do you know more than the engineers on TEAM Camaro as you have "promoted" him?? The backeddy stamp of approval means what exactly? < All fair and important questions to qualify who we listen to. Quote:
OP, we are all very free with our opinions on the forums, but that is all they are, opinions. Good luck. Matt
06-30-2015, 12:02 PM | #10 |
So it seems like people like to put the z28 coils on their 1le struts. How much does this cost? Is it a direct fit?
06-30-2015, 12:52 PM | #11 | |
The Z/28 springs are not a direct fit to the 1LE struts. The spring rates are also too high for the 1LE struts to effectively handle. The Z/28 springs are sold for $337.18 for all 4 (front Z/28 springs are $80.75 Each, rears are $87.84 each).
06-30-2015, 01:22 PM | #12 |
Damn!
All I want is to lower it a little. Is there really no way that won't cost an arm or a leg or give me a crap ride. Last edited by cabbe; 06-30-2015 at 01:35 PM. |
06-30-2015, 03:32 PM | #13 | |
If you can do the install yourself you should have about $200ish into it, if you need o pay someone I would hope it wouldn't be more than $160....so $360 or so total. There are pictures on my build thread (in my sig) of my car stock, with only the Pedders 30mm springs on the rear and then with front and rear springs. Page 1, Post #9
