04-15-2015, 09:22 AM | #1 |
Drives: 1987 IROC-Z 5.7L 2016 1SS M6 NGM Join Date: Jan 2015
Anyone ever power brake a V6 automatic?
Just wondering. I have a manual, and was having one of those crazy ideas that I will reveal if encouraged.
04-15-2015, 09:40 AM | #2 |
Drives: 2014 2SS/RS Camaro Join Date: Dec 2014
I rented a V6 auto. I may have power braked it... lol
Whats up?
2014 2SS/RS, L99, SW LTH w/HF Cats, GMPP Ex. Z/28 CAI, FR41s in PVD Black Chrome, Recaros, Pfadt Sway
377hp, 383tq 12.739@110.44 MPH |
04-15-2015, 10:30 AM | #3 |
Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
Sure you can, tell us your crazy idea!
04-15-2015, 10:34 AM | #4 |
Drives: '14 RRM 1LT/RS A6 Join Date: Mar 2009
Maybe.
04-15-2015, 10:42 AM | #5 |
having FUN now 13.66@101
Everytime I lined up at the dragstrip and was heating up the drag radials.
04-15-2015, 11:31 AM | #6 |
I did every race and got off the line quicker than any SS I was against. But then they blew by lol
http://www.camaro5.com/forums/showthread.php?t=387407
04-15-2015, 12:10 PM | #7 |
No officer, never have...
CAI intake | OBX LT Headers | Flowmaster AT Exhaust | Trifecta Tune | SS Rear Diff, Axles & Driveshaft Zex 100 Shot Nitrous | Konig Airstrike Wheels | Custom Engine Cover, Fuse Box & Underhood Bowtie Eibach Springs & SS Sway Bars | BMR Strut Brace | Drake Shifter | Vitesse Paddles | 13.26 @ 105.88 mph |
04-15-2015, 12:56 PM | #8 |
Here's the deal. I was thinking about doing a slow rolling burnout in second gear. I have a manual, and when I roll in second gear, lightly apply the brakes, and gas it... Nothing cool happens. I was thinking about disconnecting the wheel speed sensor to disable the abs. Allowing me to overpower the rear brakes, and do a sweet burnout. Not interested in ruining the clutch, or installing line lock. Just a quick override. But since it is possible with the automatic, it seems like it should be possible with the manual. My 96' 3.8 m5 could do it in first, but didn't have enough power for second. I did it in a 2001 Mach 1 Stang second gear no problem. It's kinda abusive, I know...
04-15-2015, 03:02 PM | #9 |
Install a line lock and try to set your brakes about half way before you activate the line lock. That way your front brakes aren't on full, but there is enough of a drag to keep you from speeding out of it. With the V6 the line lock helps out a ton so you don't have to power through the rear brakes as well. I haven't driven a manual V6, so I don't know how it would react to trying to start a burnout in 2nd.
04-15-2015, 03:13 PM | #10 |
The gritos pollo!!!
Good luck with the second gear burnout, you will hurt the clutch more by doing this. This motor has no low end torque so even if you pull the abs nothing is gonna happen, You are gonna need some rpms to do it. Let it creep in first gear (5mph) and once the clutch is out Mash the gas. There is no problem spinning them.
It's annoying to see all the "I can't spin them" threads. I hate you all and envy your problem
______
If you don't stop how can they give you a ticket?-The Big Tuna___ '12 1Ls Camaro; Slp loud mouth I|maganflow x-pipe|Injen long ram intake|brembo brake upgrade| russell s.s. lines|2LT polished 19's|billet 5mm spacers|tinted tail lights&markers|pdmi|billet c. can| '13 Avenger R/T '77 T/A 6.6;, draining my wallet. |
04-15-2015, 06:32 PM | #11 |
I can spin them no problem, spins in a power shift to second. But doing a burnout in first is like doing a wheelie in first. It's fun for a couple seconds then you run out of rpm. Line lock is the way to go, sounds much safer. Thanks everybody! I agree, all those "it won't break em loose " leave me wondering.
04-17-2015, 03:22 PM | #12 | |
Drives: 2012 Camaro 2LT RS Join Date: Mar 2012
I run a Hurst line-lock works great.
04-17-2015, 04:05 PM | #13 |
Drives: 2014 Camaro 2SS RS Join Date: Aug 2014
a stock v6 can spin tires?
04-17-2015, 08:38 PM | #14 |
