Old 08-21-2013, 11:42 PM   #1
BackinBlack
KASPR
BackinBlack's Avatar
Drives: 2010 Black 2SS RS LS3
Has anybody installed the Functional Mailslot from ACS?
Check it out here:
http://www.phastekperformance.com/20...t-33-4-073.htm
I'm considering buying it and just curious what your experience with it is?
BackinBlack is offline   Reply With Quote
Old 08-22-2013, 12:07 AM   #2
Johnthegreat
Johnthegreat's Avatar
Drives: 2012 2SS/RS black camaro
Me to.
Johnthegreat is offline   Reply With Quote
Old 08-22-2013, 12:09 AM   #3
dixonk
dixonk's Avatar
Drives: 2011 Audi Q7
Send a message via Skype™ to dixonk
Best I could read up on it is that the air doesn't actually go anywhere. Doesn't hit the radiator or the engine. I could be wrong but I did read a few pages into the thread on this. Didn't strike me as a worthwhile mod.
dixonk is offline   Reply With Quote
Old 08-22-2013, 12:19 AM   #4
SSGUNNER
Chu no guat a hasa is?
SSGUNNER's Avatar
Drives: 14 Jeep G Cherokee Overland HEMI
Also thought about doing this but want sure if theres any benefit from it.
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
SSGUNNER is offline   Reply With Quote
Old 08-22-2013, 12:23 AM   #5
dixonk
dixonk's Avatar
If there are I sort of wonder why GM didn't make it functional.
Old 08-22-2013, 02:08 AM   #6
jamaro2011
jamaro2011's Avatar
Drives: summit white 2011 l99 ss/rs
jamaro2011 is offline   Reply With Quote
Old 08-22-2013, 03:30 AM   #7
Scooter18155
Scooter18155's Avatar
Drives: 2010 ss/rs 6 speed manual
Too bad you couldn't make it as a functional ram air. That's what I was thinking when I first seen the post.
2010 camaro ss/rs, standard 6 speed, ls3 motor, bmr subframe connectors, jba 3” competition Exhaust, stainless works 1 7/8" headers, adm cold air intake, hurst short throw shifter, bo white ported tb, mishimoto aluminum radiator, mishimoto oil cooler.
Scooter18155 is offline   Reply With Quote
Old 08-22-2013, 04:31 AM   #8
OzzySS
OzzySS's Avatar
Drives: 2013 2SS/1LE, 2004 Cavalier
I did a little research on this a while back...not worth it, especially for the money. There're really only three things to do with the mail slot - vinyl in front of it, delete it, or put the scanner on it.
If you want air flow, there are functional ram air hoods made, I think westcoastcamaros have several options. I'm sure there's at least a few more if you dig
Build thread linked in the pic...
OzzySS is offline   Reply With Quote
Old 08-22-2013, 07:16 AM   #9
BackinBlack
KASPR
Thanks for the response OzzySS.
It looks like the Camaro in your sig pic has HexVents. I would have thought air coming in from the mailslot and going out through those vents would really help cool underhood temps, especially on a car that had a S/C.
When you say its not worth it, were you thinking in terms of horsepower gain for the cost of the mod? Or some other critieria?
I'm not sure I like the look of the ram air hoods so was looking for an alternative.
Old 08-22-2013, 07:33 AM   #10
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
With the placement and the size, it wouldn't flow much air into it to make much if any difference. Certainly not enough to justify the cost and hassle.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 08-22-2013, 10:35 AM   #11
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
but if it could be modified to feed into into the Vararam or New Era OTR intake... it could be fully functional, and in high demand.
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 08-22-2013, 12:52 PM   #12
BenningJ
BenningJ's Avatar
Drives: 2013 AGM 1SS/RS LS3
The amount of air flow that would go through that small of an opening would severely choke the engine. You would have to make some significant modifications to the front fascia to make it worth while.
Does the ACS functional mailslot work. Sure. It will decrease engine bay temps a little and reduce the overall lift but it was designed to go with ACS hood ports and front T3 ports.
I really like my HexVents.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts
BenningJ is offline   Reply With Quote
Old 08-22-2013, 12:52 PM   #13
IMJ
IMJ's Avatar
Drives: 2012 SS LS3 | Silver Frost Metallic
This would be a nice compliment to the Vararam V6 unit, I think.
__________________________________________
Ironman John
IMJ is offline   Reply With Quote
Old 08-22-2013, 01:03 PM   #14
CFD
Drives: 2SS/RS L99 BLACK
There is quite a bit you can do with the mail slot to make it functional. There are quite a few pictures of what I did with mine in my build thread, especially on pg 2. http://www.camaro5.com/forums/showthread.php?t=170726
CFD is offline   Reply With Quote
