01-22-2015, 12:43 AM | #1 |
Drives: Camaro 2LS Join Date: Oct 2013
GM/Buick/Chevrolet Remote starter kit
iDatalink GM7 + CompuStart 1 way BAM
The kit was used only under 1 month. They look like new. Add remote starter to your car in less than 15 minutes. You can use the separate provided key fob or your factory key fob (press Lock x3) to start your car! You can install by yourself with an easy-to-follow instruction. No cut or slicing. You can restore your car to original state any time you want. Many cool configurable functions: Remote Start: Get a head start on the weather outside by remote starting your engine. Cold/Hot Automatic Start: Set your vehicle to automatically start at a certain time or temperature. Manual Transmission Compatible: Compustar Remote Starters can be safely installed on most manual-transmission vehicles. Diesel Engine Compatible: Compustar Remote Starters will work on vehicles with diesel engines. Turbo Timer: Keep your engine running in idle to prevent premature turbo wear. Lock: Secure your vehicle by locking your doors. Activate by pressing lock button. Unlock: Access your vehicle by unlocking your door. Activate by pressing unlock button. Convenience Features Valet Mode: Turn off remote start settings whenever you submit your vehicle for servicing or valet. ...and many more $170 shipped Last edited by yellowStorm; 02-06-2015 at 11:23 PM. |
01-22-2015, 09:22 AM | #2 |
Drives: 2010 WHITE SS Join Date: Nov 2014
Reason for selling?
01-22-2015, 08:48 PM | #3 |
It works just fine. There is no problem with the kit but I just got the factory remote starter installed recently. If you don't mind carry the extra compustart key fob then you'll save a lot of money as I paid $600 for the factory remote starter at my dealership.
