12-14-2011, 04:16 PM | #1 |
Drives: 2010 SS, 06 SRT10 Ram Join Date: Nov 2011
Auto Tranny Fluid Question
Cars at the shop. Me and mechanic working out on. Just got the cam in now pretty much putting the motor back together converting it to ls3.
Tranny fluid leaked out and I gotta replace some of it. What is the AUTO tranny fluid to use? I saw a thread saying Dexron. Not sure what's available here at the auto store though. Will any auto tranny fluid suffice? Or does it HAVE to be a specific one? I put 10w30 oil in it, for example, instead of 5w30 because of the climate/weather here. Just wondering if any differences in tranny fluids? |
12-14-2011, 04:25 PM | #2 |
I'm trying to follow what you are asking. Did you say you put motor oil in the transmission? 5w30 and 10w30 is engine oil and not transmission fluid.
12-14-2011, 04:29 PM | #3 |
I followed you just fine. I am not sure if it matters. I assume you already checked your manual.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
12-14-2011, 04:32 PM | #4 |
by Odeon
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM Join Date: Nov 2011
Of course it matters......
Red Line or Amsoil will do you some good.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time." "The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy." 2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's) |
12-14-2011, 04:36 PM | #5 |
Dexron is a transmission fluid spec. If you have the Auto use Dexron VI. Mobil one sells some good stuff.
http://www.mobiloil.com/USA-English/...on_VI_ATF.aspx |
12-14-2011, 05:12 PM | #6 |
Retired Navy
Drives: 2010 2SS/RS Join Date: Mar 2011
What ever fluid you use make sure it is Dexron VI in a 6L80e. Manual tranny's do not use Dex6, they use the obsolete standard Dex3.
Retired Navy... A Husband. A Dad. A Veteran as of 2011. 2010 2SS/RS A6 - FlowMaster CatBack - I'm not a Amsoil dealer and will never be one. I believe in its capabilities from personal use with oil analysis reports backing up my OCI's. Besides, I know more than most cut and paste Amsoil dealers which are at least 95% of them.
12-15-2011, 11:22 AM | #7 |
Are there any fluids that are compatible with dex6?
I can't find any in my country :/ All I find is dex3 and multi vehicle ATFs. |
12-15-2011, 11:30 AM | #8 | |
Camaro Owner Since 1987
Drives: 2011 2SS/RS L99 RJT Join Date: Jun 2006
Good luck. Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop Rx Catch Can;Rx Breather;Roto-Fab Washer Container VMax Ported RJT Throttle Body XSPower Headers and XSPower 3" Exhaust System Elite Engineering Tunnel Brace, Gorilla Wheel Lock System; Bear Rotors, Hawk HPS Tinted Windows 35%;EFILive Tune |
12-15-2011, 11:35 AM | #9 |
Boosted Moderator
I'm going to slide this one down to the Trans section... Probably get better answers there...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. If everything seems under control, you're just not going fast enough. Mario Andretti If you can turn, you ain't going fast enough... |
12-15-2011, 11:49 AM | #10 |
Better question.
On a ls3 conversion / cam upgrade, how much tranny fluid do you lose? Does it HAVE to be replaced? |
12-16-2011, 05:50 PM | #11 |
You must use Dexron VI. Yes it is recommended to fill the transmission if fluid is lost. There is a special filling and check procedure.
12-16-2011, 07:37 PM | #12 | |
Bill
12-19-2011, 02:57 PM | #13 |
04-13-2012, 08:51 PM | #14 |
Emerald Coast Camaros
Drives: 2010 2SS/RS Camaro IOM/IO Join Date: Aug 2009
Where is said dipstick??? I'm trying to find and can't.
ECC on Facebook
2010 Camaro SS/RS IOM, IO interior, Custom Striping, Razzi body kit ADM CAI w/scoop/Dynatech Headers & Hi-Flow Cats/Solo Performance Exhaust, FTI 3600 Stall/Comp Cams custom grind cam/LS3 conversion/FAST 102 Intake |
Similar Threads | ||||
Camaro ZL1 Laps Nurburgring in 7:41.27. Enters Supercar Territory!! | Tran | Camaro ZL1 Forum - ZL1 Specific Topics | 547 | 11-15-2011 01:53 PM |
V6 Brake advice | Cyber Gray | Suspension / Brakes / Chassis | 70 | 08-26-2011 05:19 AM |
Might be a dumb question, SS tranny into V6? | DarkneSS | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 6 | 07-24-2011 06:34 PM |
Diff Fluid and Tranny Fluid | jagan323 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 11 | 03-15-2011 06:45 PM |
