08-09-2010, 08:34 PM | #1 |
Drives: 01 GMC 4x4 ecsb "Force Feed" ;~) Join Date: May 2010
Pulley size on a KB 2.8
How small of a pulley can you run on a KB 2.8 with stock 6 rib setup. I'm currently running a 3.75, but I have a 3.25 I want to try. Do you guys think it will spin it with much belt slip. BTW, this is on a forged LS1. in a 01 GMC truck.
08-10-2010, 10:47 AM | #2 |
Drives: 2SS/RS LS3 RJT Join Date: Jun 2009
You can contact Jeff at total performance engineering. He specializes in LS KB applications.
08-10-2010, 09:25 PM | #3 |
I've sent him a couple emails and didn't get replies, so i thought I would ask here since this is the most active site I have found for KB blowers. Anyone pulleying down on 6 rib setups??
08-10-2010, 09:42 PM | #4 |
Try calling, he's always busy. He'll answer the phone if he is in.
08-11-2010, 12:25 PM | #5 |
Drives: C63 P31 Join Date: Feb 2010
I would call Kenne Bell's technical support. You will probably get an answer pretty fast.
08-11-2010, 03:33 PM | #6 |
I was kinda looking for real word experience... :o/
Guess I will just have to try it and see. |
08-12-2010, 11:18 AM | #7 |
Drives: My wife crazy with my C5 usage. Join Date: Apr 2009
Send Adam@ST a pm if you can't get Jeff@TPE.
08-15-2010, 09:02 PM | #8 |
Well, I went ahead and tried it and it sort of works, lol. I'm only making about 13-13.5lbs of boost and a bit of belt dusting, so I know its slipping some. Blower just takes too much power for a 6 rib to hold. Stretches the belt enough that the tensioner can't keep the belt tight enough for it not to slip a little. I have everything for the 8 rib setup but the balancer pulley, I just wish they weren't $550... :(
10-25-2010, 09:59 PM | #9 |
Drives: 01 vette w/a KB. 91 Zr1 415 stroker Join Date: Oct 2010
1psi for every 1/8 inch reduction in pulley size is what I believe Mike@kb said once.
10-27-2010, 12:13 AM | #10 | |
R6P Marketing Lab Rat
Drives: sometimes Join Date: Feb 2009
I don't know how the ford and dodge folks deal with this with KB but please keep us up to date as things develop and good luck. I also just found this. Seems that to keep the KBs in control they went to great lengths. http://forums.corvetteforum.com/c5-f...cket-pics.html
10-27-2010, 08:09 AM | #11 |
Drives: 1999 Trans Am Join Date: Jul 2009
Making power with a blower and avoiding belt slip is always a problem.Happens with all the blowers. Getting 13lbs out of a blower without slip is good. Being dissapointed that you can't get 16lbs out of a 6 rib is just foolish.
Sounds like you need to make the jump to the 8 rib overdrive pulley. Not a big deal for the power/boost you want to push. |
Similar Threads | ||||
DIY : Install underdrive pulley on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 34 | 09-30-2013 08:25 PM |
WHAT BELT SIZE DO I NEED FOR POWERBAND PULLEY? | BlessedChef10 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 1 | 04-14-2010 08:34 AM |
Does anyone have any idea what size belt or part number is needed for this pulley. I | BlessedChef10 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 0 | 03-10-2010 04:03 PM |
Powerbond pulley belt size for V6? | BlessedChef10 | USA - California | 3 | 03-10-2010 04:00 PM |
pulley size? | camaro1 | Forced Induction - V8 | 3 | 02-09-2010 05:11 PM |
