05-22-2011, 12:50 PM | #1 |
Drives: 2011 ss rs Join Date: Dec 2010
My 2011 has solid Cradle bushings!
I went to Haddad Motorsports to have the Pedders Street 1 bushing insert kit installed. When they were on the cradle bushing insert part of the install they discovered that the stock bushings no longer had holes/slots. It looks like GM has made a change mid-stream to the solid bushing. This new bushing is deffinatly stiffer than the old ones. I had Mike remove the stock bushing anyway and replace it with a new Pedders bushing. To make a long story short the cradle bushing inserts in the current Pedders Street 1 package will not work on a late 2011. I've included photos of the GM bushing. Mike and his crew at Haddad did a great job on the install. I'm very satisfied. Really tightened up the car. Hat's off Mike Thanks!!
05-22-2011, 02:23 PM | #2 |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
I plan to add full track bushings to my car anyway, late 2011s have a lot of things the earlier cars don't have, that's what we get for being guinea pigs. The ls3 I was supposed to get has Zl1 strut towers with holes for GM strut brace, no drilling required. Funny I should say that because I am now in the process of drilling my holes for my Pfadt brace install.
05-23-2011, 10:27 AM | #3 |
Drives: '11 2SS/RS RJT M6 Join Date: Oct 2010
OP, did you have the rear end step out that plagues the other bushings or did you upgrade for a different reason? I've got an early 2011 without the strut tower change for the convertible brace. I've got the inserts and was going to install them because of the step out. Would hate to waste my time doing the work to find out that I can't use them.
Vararam CAI, Elite Engineering Catch Can, Separate Clutch Fluid Reservoir, Ghost Armor Full Protection Package, Chromed Turn Signal Bulbs, RPI Stealth Splash Guards, Skip Shift Eliminator, Defenderworx Chrome Bowtie Inserts, Pfadt Trailing Arms, Camaro Decal Store CGM Hood Spears with "376ci" custom text, Billet Depot/Drake Underhood Polished Caps, CGM Lug Nut Decals, Pedders Front Radius Rod Inserts, JacFab Front License Plate Bracket
05-23-2011, 11:21 AM | #4 | |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
-Blair |
05-23-2011, 12:49 PM | #5 |
Drives: 2011 imperial blue SS, black 92 RS Join Date: Apr 2011
Can I tell if mine has these upgraded bushings without taking it all apart? I bough nine about a month ago, it wasn't on the lot very long before I bought it and I do have holes in the strut tower for a brace.
05-23-2011, 12:58 PM | #6 |
Drives: Camaro Justice Join Date: Jun 2007
The new bushes were designed to improve the rear end step out present in the 5th gen. They were first installed in the Verts and are now standard equipment across the line. While there is more rubber in the redesigned bushes there are still significant voids. Adding sub-frame inserts or full replacement bushes is still the single most important foundational modification you can make. At Rodgers Chevrolet Pedders Day about ten days ago Becky had a six with the new bushes and Pedders inserts. Every single person that drove the 5th Gen with the inserts walked away saying the same thing. How can Pedders inserts make such a big difference? The answer is simple. The voids in the redesigned bushes are still huge. Allow me to show you.
In this photo you see the fingers on the inserts that fill very thin voids in 5th Gens built prior to late March. To fit a Pedders EP1200 Insert Kit on a 5th Gen, use a pair of side cutters to trim the very thin fingers off the inserts. In this photo, we have covered the fingers with white paper. As you can see, what remains is 95% of the material to fill the voids in the revised OE bushes. If you have an air hammer, you can have the lower plates out in a matter of seconds. Btw, I wonder where GM got the idea to fill in at least part of the void in the sub-frame bushes Last edited by JusticePete; 01-04-2012 at 10:48 AM. |
05-23-2011, 12:59 PM | #7 |
Check your build date. If it was built before March 2011 you have the older style more open bush.
05-23-2011, 01:04 PM | #8 | |
You will not be wasting your time. The inserts will fit both the original and updated OE sub-frame bushes. With the new OE sub-frame bushes you do need to trim your Pedders EP1200 inserts. Use a pair of side cutters to remove the thinnest part of the Pedders red inserts so what you install looks like this. Without the white paper of course If you have an air hammer, you can have the plates out in a matter of seconds. |
05-23-2011, 01:39 PM | #9 |
My 2011 was built in January. It has the new bushings
05-23-2011, 01:42 PM | #10 |
GM has not made public the date the change was made. The earliest cars we have seen with the revised bushes, aside from all the Verts) was March. The more information we get from C5 members, the more accurate our change date will be. Thank you for posting.
05-23-2011, 02:22 PM | #11 | |
Edit: Looking at the image #s you posted the same pic twice.
[B]
05-23-2011, 03:59 PM | #12 | |
05-24-2011, 11:32 AM | #13 |
Shop Owner
Drives: 1 ton silverado Join Date: Jan 2009
Mike and his crew always do a great job.
05-24-2011, 04:36 PM | #14 | |
Drives: Camaro Join Date: Jun 2009
Good to hear and we're happy that your happy Thank You |
Similar Threads | ||||
Transcript of Camaro ZL1 Q&A Webchat with Chevrolet | Tran | Camaro ZL1 Forum - ZL1 Specific Topics | 42 | 12-22-2017 04:42 AM |
Pfadt Street/Race Rear Differential Bushings, get more power to the pavement! | Apex Motorsports | Transmission / Driveline | 5 | 08-10-2010 05:49 PM |
2011 Camaro Pricing Announced on Edmund's Inside Line | LostInMoscow | 5th Gen Camaro SS LS LT General Discussions | 3 | 06-03-2010 01:36 PM |
Reinforce Your Oe Fr. Radius Rod Bushings Yourself | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 8 | 05-19-2010 11:52 PM |
