07-14-2011, 11:37 AM | #1 |
More then meets the eye!
solid cradle mounts
Dose anyone know if there is another company that makes solid cradle mounts? The Pfadt is very nice and pricey.
2010 2SS/RS, M6, OBX 7/8" l/t headers, with high flow cats, MBRP full 3" exhaust, Whipple supercharger, 3.875 pulley, ID-1050X 1260CC injectors, JRE rough idle street blower cam kit, ZL1 fp, ZL1 fpcm, ZR1 3 bar map sensor, cold air intake, Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidamper, MGR shifter, and tune by Jannetty Racing.
07-14-2011, 11:40 AM | #2 |
knows 2 facts about ducks
I think Pedders does, but not sure.
07-14-2011, 12:05 PM | #3 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
If by solid you're referring to solid metal, Pfadt is the only one. Pretty much all the bushing companies make a solid bushing of varying material.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
07-14-2011, 02:56 PM | #4 |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
Our solid subframe mounts may be a little more expensive than some, but you can rest assured that your Pfadt Solid Subframe Mounts are the most complete solution to eliminating rear subframe movement, without significant increases in Noise/Vibration/Harshness. The Corvette rear subframe has been bolted directly to the chassis for a long time now, and that's essentially what these mounts are achieving. For cars that see nothing but street time, to full on race car builds, we feel our Solid Subframe Mounts are the best aftermarket solution to rear subframe deflection.
07-14-2011, 03:52 PM | #5 |
Search Ninja
Damn you kill me when you post those pics. They're like suspension porn.
Don't you need another independent tester for streetability?
07-14-2011, 03:55 PM | #6 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
Damn, I'd like to find a box of those at my house!
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
07-14-2011, 03:58 PM | #7 | |
Drives: Wagon Queen Family Truckster Join Date: Oct 2009
07-14-2011, 04:04 PM | #8 |
Drives: Race Car Join Date: Sep 2009
We are going to have the BMR solid Delrin cradle bushings ready to sale early next week. Here is quick teaser picture for you guys.
07-14-2011, 04:39 PM | #9 |
07-14-2011, 04:42 PM | #10 |
07-14-2011, 06:45 PM | #11 |
Drives: 2010 IOM 1SS M6 Join Date: Jun 2011
07-15-2011, 02:03 AM | #12 | |
I was thinking the same thing.
07-15-2011, 02:20 AM | #13 |
Chase, I got the BMR toe rods the other week, I bought the trailing arms awhile ago, and I wanted to do the cradle, and diff. bushing the same time I do the toe rods. I almost bought the BMR poly kit. I think ill wait for the delren ones from BMR. I also wanted to thank APEX-SPEED for being a great company for the fith gen Camaro.
07-15-2011, 05:31 AM | #14 | ||
Similar Threads | ||||
Pfadt solid subframe mounts - who's got them installed? | AdamCzap | Suspension / Brakes / Chassis | 35 | 07-27-2011 05:24 AM |
My 2011 has solid Cradle bushings! | curts11 | Suspension / Brakes / Chassis | 15 | 05-24-2011 06:29 PM |
Any Central Jersey members with upgraded poly or solid rear cradle bushings? | robertway | USA - NY / NJ / PA | 1 | 02-07-2011 07:24 PM |
Pfadt solid subframe mounts, diff bushings, sways and trailing arms installed! | AdamCzap | Suspension / Brakes / Chassis | 14 | 01-04-2011 05:54 PM |
Pfadt Engine Mounts installed, first and second impressions... | robertway | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 6 | 03-03-2010 09:35 AM |
