04-05-2011, 10:01 PM | #1 |
Drives: Camaro Vert & Avalanche Join Date: Nov 2010
BMR lowering spring?
I instaled a set of BMR lowering springs -1 on my car this past weekens and I cut the bunp stops did I need to do this?
04-05-2011, 10:20 PM | #2 |
Drives: 2019 F150 RCSB Abyss FX4 Join Date: Aug 2009
You better glue it back on or your car will never drive right again.
just kidding!! |
04-06-2011, 04:40 AM | #3 |
Cutting the bump stops will help regain some suspension travel and prevent bottoming out. Having grown up driving Louisiana roads, I think it was a very good move.
04-06-2011, 06:06 AM | #4 |
04-06-2011, 06:07 AM | #5 |
04-06-2011, 09:39 AM | #6 |
Drives: Race Car Join Date: Sep 2009
You don't have to cut the bump stops with our springs, but like everyone else said you will be perfectly fine doing so.
04-06-2011, 09:45 AM | #7 |
US Veteran
Drives: 2011 Silver Ice Metallic 2SS/RS A6 Join Date: Jan 2011
So True! The roads absolutely suck here!
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS) |
04-06-2011, 10:15 AM | #8 |
Drives: BLACK 2SS/RS Join Date: Sep 2009
Im lowered 1" and have not cut them and i have never bottomed out yet.
CCW polished 505a's
Front 20x10 w/275/40/20's Rear 20x11.5 w/305/35/20's Eibach 1" Pro Spring Kit Factory GFX MPD1 spoiler painted bowties 15% tint |
04-06-2011, 10:17 AM | #9 |
Cool thanks for the help guys
04-06-2011, 10:37 AM | #10 |
Drives: 89 IROC 350 Join Date: Mar 2009
I cut mine... No issues!
04-06-2011, 02:25 PM | #11 |
Im thinking about getting some new ones and installing them uncut because my back tires are rubbing just a little and I think it would help
04-06-2011, 04:21 PM | #12 |
Drives: 2010 1SS Join Date: Jan 2010
As Kyle mentioned it is not necesarry but isn't going to hurt anything either. The OE bumpstop is progressive. The first inch or so is very soft and as it is compressed it gets progressively stiffer. Removing the soft portion will just remove that progression and make the hit a little more stiff when it does touch.
04-06-2011, 04:43 PM | #13 |
Where are your tires rubbing? Cutting them should have no effect on your tires rubbing.Are your wheel offsets correct? Plenty of members running 315/35's and lowered 1.5" w/no rubbing issues.
CCW polished 505a's
04-06-2011, 05:22 PM | #14 |
I think the tires rubbed off the part that was hitting now and I got the rest with a dremel tool. The offset on the wheels are just a little too far out .25" in would have been spot on
Similar Threads | ||||
1 inch and 1.4 inch BMR Lowering Springs Now Available At APEX Motorsports!!!!!!!!!!! | Apex Motorsports | Suspension / Chassis / Brakes | 273 | 04-25-2016 05:17 PM |
Pfadt Race Engineering DIY Drop Spring installation procedure | PfadtRacing | Suspension / Chassis / Brakes | 20 | 09-23-2011 09:31 PM |
Raising/Lowering the car | Rocky918 | Suspension / Brakes / Chassis | 28 | 03-18-2011 11:03 PM |
SUSPENSION QUESTIONS ? | 1969to2010 | Suspension / Brakes / Chassis | 23 | 11-05-2010 01:58 PM |
BMR Lowering Springs - How It's Made | BMR Suspension | Suspension / Brakes / Chassis | 40 | 06-22-2010 10:32 AM |
