03-28-2012, 10:41 PM | #1 |
Drives: Black 2012 1LS Join Date: Nov 2011
Swirl marks after washing
I hate it! I try and keep my car as clean as possible but everytime I wash it it just creates swirl marks everywhere. And I'm really careful with how I wash and the technique and procedure I use. Is this just me or does this happen to other people? What can I do to get rid of the swirls? Something I can do at home.
03-28-2012, 10:43 PM | #2 |
Drives: 2013 Fiat 500 Abarth Grigio Join Date: Apr 2011
U bought the wrong color black is extreamly hard to keep clean and keep it swirl free. Ive owned plently of black vehicles and no matter what i have tried they always have ended up with swirls at some point and time. Are u useing different rags for top of car and bottom of car and two different buckets? Are u washing out the mitts after each wipe.?
03-28-2012, 10:47 PM | #3 |
Your technique, wash media, drying methods, or all of the above are wrong. Do a search and you'll find all your answers.
Here's a PDF I put together that will be helpful for you. Don't bother worrying about correcting it until you've learned to stop causing it. Then we can talk about correction.
[B]
04-02-2012, 09:13 AM | #4 |
Adam's Distributor
Drives: 1988 Base Coupe, 1991 Z28 Join Date: Jan 2012
Was the car ever "Perfect"? Don't forget that dealers and their "wash crews" do a fine job of installing swirls before you ever buy the car. Also, some waxes and products fill swirls, so your car may appear to be perfect, until those products are washed away. Lots of possibilities here.
If you are ever in Orlando, please let me know and I'll help you with your specific situation and get you on the right track.
Florida's Distributor of Adam's Premium Car Care Products Same Prices and Fast Delivery Call or text at 407-257-9604 ~ Email at mike@xqizt-automotive.com ~ Facebook.com/XQIZTAUTO |
04-02-2012, 09:17 AM | #5 |
knows 2 facts about ducks
did you use the two bucket method?
04-03-2012, 05:28 PM | #6 |
Drives: ? Join Date: Oct 2011
04-03-2012, 11:13 PM | #7 |
Drives: Like I Stole It! Join Date: Jun 2009
what soap are you using? what mit/sponge? What kind of drying media?
04-27-2012, 12:08 PM | #8 |
Drives: 12 LS M6 All Blk Join Date: Jul 2010
I have the exact same problem!!!! Seems to be getting worse!!!
2012LS 3.6L M6 All Black
Custom mats by Llyods/ AAC colorshift 2.0 halos ,footwells/ HID/LEDS by AAC/ Aqua interior and trunk/ Black billet upper and lower grilles/ Black billet bowties.MRT V2/Magnaflow X pipe/Rx catch can and oil breather cap/ C.A.I. Intake/Scoop/ww relocater/Hurst Short Throw Shifter |
04-27-2012, 12:28 PM | #9 |
Drives: The shiny ones. Join Date: Mar 2010
Elaborate a little on your process "Washing" is such a broad term and subject to so much interpretation. Unless you're following a good process it doesn't matter one bit how "careful" you are, bad technique is bad technique.
Are you spending time with a decent amount of water pressure rinsing before soaping? Are you making sure to use separate tools and cleaners for the wheels and paint? Are you using a high quality soap with lots of lubricity? Are you using high quality wash media? Are you working top down and segmenting the car with separate wash pads/mitts? Are you performing a 2 bucket wash with grit gaurds? What are you using to dry? Are you using a drying agent to reduce the chances of swirling? |
04-27-2012, 12:52 PM | #10 |
Drives: 2010 Mazdaspeed 3 Join Date: Mar 2012
Great points Dylan!
I have seen proper technique that consisted of using a rough old cotton towel to 'scrub' the paint clean and dry the paint. First, lets look at what creates swirl marks... Swirl marks are tiny microcopic scratches that are created when dust,grit,abrasive medium abrades the paint's surface unevenly. These tiny scratches radiate outward from a central light spot, giving them the appearance of being circular. To reduce the chance of creating swirl marks we have to systematically look when you are touching your paint and what you are touching it with. Let's start with towels and applicators. What type of towels are you using on your paint' surface? Are they terry cloth, microfiber, quality microfiber, leather chamois? If you are using cotton is 100% cotton or does it feature a nylon (scratch causing) backing. Can you pressure the cotton against your face with out it scratching? Many detailers and enthusiasts have switched to microfiber towels, but cheaper microfiber towels can scratch paint pretty quickly. Use plush, soft microfibers such as the Supreme 530. When applying wax what are you using and what are you removing it with. Only use soft materials like a soft poly foam appilcator to apply it and a soft microfiber to remove. So the car is dirty, how to you remove the abrasive grit with out scratching? Here is an article I have written for our webstore, but I can post it here if this helps. You've spent plenty of money on the purchase of your car or truck, now the question arises, “How do I take care of it?” Proper washing is one of the most overlooked and misunderstood areas of auto care, and sadly improper washing damages and dulls your vehicle's finish over time. If you take a second and look at the cars around you in a parking lot, or even at a car show, in the direct sunlight you will notice many of the cars have a scratched surface. These microscopic scratches seem to radiate outward in a “cob-web” effect from a central light source like the reflection of the sun. Many of the swirl marks are the result of improper washing and drying techniques. They are caused when grit is abraded against the paint's surface. PICTURE OF SWIRL MARK FINISH Much has been written on how to properly maintain a vehicles appearance and while most of the tips in this article certainly aren’t new, perhaps they may help you think about things in a different light. Vehicle enthusiasts range from those who religiously wash or quick detail their vehicles daily, to those who love caring for their vehicle but only get the chance to wash them weekly or bi-weekly. Both categories of enthusiasts cringe at the very thought of taking their car or truck to a car wash, otherwise known as “automatic swirl factories”. In this article we hope to give you some ideas and tips that will help you maintain your vehicles appearance and teach you ways to avoid, or at least minimize creating swirl marks. Car Wash Shampoo Car wash shampoos have come a long way since their introduction to the automotive detailing market. There was a time when we all just grabbed dish soap and went to work but those days are long gone. Dish soap is designed to eat away grease and food and while it works great for dishes but we need to keep it in the kitchen! The same attributes that break down the grease on dishes will strip your car wax and dry out your plastic moldings and rubber seals! Some of the factors that establish a great car wash shampoo like BLACKFIRE Wet Diamond Conditioning Shampoo are foaming ability, lubricity, pH balance, concentration, gentleness and even gloss enhancers. High quality car wash shampoos will clean a car’s surface, enhance the gloss and leave the car wax, paint protectant or paint sealant intact to protect your paint. Generic car wash shampoos that you could purchase in bulk at a clearance or discount stores lack many of the attributes of the higher quality car wash shampoos. You will also find that the cost of the bottle of car wash shampoo does not necessarily mean it is less expensive. The high end car wash shampoos like the P21S Bodywork Conditioning Shampoo or Ultima Paint Guard Wash tend to cost more per ounce but they are also more concentrated so if you do the math, you may find that you are actually getting a better deal with a premium car wash shampoo. All car wash shampoo's carried by Autopia are tested and of the highest quality. If you are not sure which shampoo will work best for you it is often advisable to stick with the same brand that your car wax or sealant is. If your paint is protected with BLACKFIRE Wet Diamond All Finish Paint Protection then use BLACKFIRE Wet Diamond Conditioning Shampoo, if your paint is protected with a fine coat of P21S Concours Carnuaba Wax than P21S Bodywork Conditioning Shampoo is a great choice. If you still cannot decided give Autopia Car Care a call at 1-877-855-3125 and let our experts choose for you! Car Wash Mitts Ask a group of car enthusiasts which company makes better car or truck? Ford, Chevrolet, Dodge, Honda, Toyota, Lexus, BMW, Mercedes, Porsche or Audi? You will get a variety of different answers; everyone has his or her opinion! To say that everyone has a favorite is an understatement yet there are some basic fundamentals that make an item one of the best for its intended purpose. Wash mitts can be microfiber style (both short nap and the longer fuzzy monster looking type), sponges, synthetic and genuine sheepskin. The Sheepskin Wash Mitt is a great choice: They are soft, hold lots of water and car wash shampoo and they rinse cleanly. Natural Sea Sponges are some of the softest material known to man and hold a large volume of water and soap solution. The Lake Country ULTI-MITT is made from a super soft foam that is gentle to your paint and rinses easily. You want to avoid shop rags, old t-shirts, and beach towels as the nap, or thickness of these items is so small that you can easily exert too much force onto the wash surface and inadvertently push surface dirt around instilling “washing swirls.” Also, these wash “rags” do not release trapped dirt as easily. The thicker mitts offer room for dirt to hide that is away from your car until your mitt is rinsed. If you are washing a larger vehicle such as an RV or boat, or prefer using a brush instead of a wash mitt, then stay clear of nylon bristled brushes that will quickly damage, dull, and scratch paint! Montana Brand Boar's Hair Brushes features hand selected and feathered boar's hair. Once soaked in your wash solution for several minutes these hairs become amazingly soft. The Montana Boar's Hair Brushes hold an incredible volume of soap solution and make cleaning larger areas easy. Car Wash Buckets In choosing a bucket you generally have two choices, 5 gallon or 3.5 gallon. Usually the 3.5 gallon is just too small to get the job done with plenty of fresh car wash solution but with water weighing 8.35 pounds per gallon it is difficult to lug the 5 gallon bucket around your car. The solution is the BLACKFIRE 5 Gallon Wash Bucket System with Dolly! This bucket will make it much easier to quickly wash your entire car. It even comes with a lid so you can store your car wash shampoo, mitt and brushes right inside the bucket to keep them handy for the next wash. When it comes to swirl free washing, one of the greatest ideas to come along is the two bucket method of car washing. As the name implies you use two separate buckets to wash your car. One bucket holds the soapy car wash solution and the other holds clean, clear rinse water so you can rinse your mitt after each pass over your car. This keeps those dirt particles you just picked up on the surface from going back into the clean car wash solution and being picked up again by the wash mitt. This brings us to the next topic….Grit Guard® Inserts. If you aren’t using them…you should be!!! The Grit Guard® Inserts is a round plastic insert grate that sits on the bottom of your bucket suspended from the bottom by four lateral fins. Dirt from your wash mitt drops to the bottom of the bucket and is kept at the bottom of the bucket, ensuring that your wash mitt doesn’t pick up the dirt you just washed off of the car. When you finish washing your car and lift the Grit Guard® Insert up and you will see how well it works. The Grit Guard® Insert should be used in both the wash and rinse buckets for optimum protection against instilling swirl marks. The Grit Guard® Insert comes with the handy Sonus Professional Car Wash Bucket on Wheels and the BLACKFIRE 5 Gallon Wash Bucket System With Dolly. Hose Nozzles Yes, even your hose nozzle is an important part of your car wash procedure. There is nothing like trying to wash your car with an inadequate or leaky hose nozzle. The Fire Hose Nozzle and it's big brother The Industrial High Flow Fireman's Nozzle offer a wide range of spray patterns as well as the very important open flow and no leaks! The open flow option is especially important when rinsing your car to get the water to sheet off instead of beading up which will cut down on drying time and the possibility of water spots. It is also designed so you can set it down quickly without breaking or accidentally hitting a handle and giving yourself an unexpected shower. Optional Foam Guns and Foam Cannons Dirt and grit as most abrasive when it is laying in a fine dust over your paint. Even when pre-rinsing your car with water some of the grit can scratch. Both the BLACKFIRE Foam Gun and the BLACKFIRE Foam Cannon allow you to lather your car in a blanket of clingy suds that encapsulate the grime and reduce its abrasiveness. The BLACKFIRE Foam Gun attaches to your hose with a special trigger nozzle. The BLACKFIRE Foam Cannon attaches to a pressure washer. Mix in your favorite car soap or use a special blended car soap such as Detailer's Pro Series Xtreme Foam Formula Auto Shampoo and spray on. Allow the soap to dwell for several minutes then rinse off. If you paint only has a light coating of dust or road pitch you can even use the BLACKFIRE Foam Gun or BLACKFIRE Foam Cannon as a substitute for regular washing. Layer your car in a blanket of foam, lightly wipe with your favorite wash mitt, rinsing frequently in a rinse bucket, and hose off. Drying Towels Two of the most popular options for drying your vehicle are waffle weave microfiber towels and synthetic PVA towels. The PVA synthetic chamois are the small rubbery towels used by divers and swimmers at the Olympics. They are generally smaller and rubber-like in feel. They hold a large amount of water, wring out easily, and last a very long time. The drawback is that they are not quite as soft and gentle as the microfiber drying towels. Microfiber waffle weave drying towels like the Cobra Guzzler Waffle Weave Drying Towel are very soft, safe and effective. The waffle weave act like little pockets and absorb tons of water and when used properly used are extremely gentle on your vehicles surface. It generally takes only two towels to dry vehicle to ensure a spot and streak free finish. The first towel picks up the majority of water and the second towel picks up any residual moisture ensuring a streak free finish. Another benefit to the Cobra Guzzler Waffle Weave Drying Towel is that you just wash them with my other microfiber detailing towels so that each time you go to wash your car your microfiber drying towel is clean and fresh with no chance of dirt from the last car wash. Keep in mind that just like other products, there is a difference in quality when it comes to microfiber drying towels, they are not all the same so be sure to use only high quality towels like the Sonus Der Wunder Microfiber Drying Towel or Cobra Guzzler Waffle Weave Drying Towels, available in three sizes Now that we’ve discussed the tools for the job, lets just give you a rundown of how to wash your car in a manner that gets it clean and reduces the chances of your putting swirls into the paint. Always wash your car in the shade! This will keep your car wash shampoo solution from drying on the car before it is rinsed off. If at all possible, it is best to wash your car on a relatively calm day as even a slight breeze can put particles of dirt in the air. These dust particles are attracted to the wash/rinse water on your vehicle and act like sandpaper when rubbed between the drying towel and vehicle surface. The breeze will also tend to dry your car for you and this can cause streaks and water spots. Use two buckets with a Grit Guard® Insert in each bucket. One is for your shampoo solution and the other is clean rinse water for your wash mitt. Fill a 5-gallon bucket 2/3 full with cool water. Add recommended amount of shampoo to the water. Using a stiff jet of water, fill the bucket to fully activate suds. Fill the second bucket with clean, water for rinsing your wash mitt. Thoroughly rinse the vehicle’s surface to remove the loose dirt and grime before you begin your car wash procedure. If the paint is excessively dirty or you wish to add more protection, use a foam cannon to pre-soak the vehicle prior to rinsing. Only use high quality car shampoos and wash mitts. When washing your vehicle remember to always go from high to low, never the opposite. Generally the dirtiest parts of your vehicle are those parts closest to the ground. Wheel wells, rocker panels and bumpers tend to have the largest accumulation of grime and you don’t want to bring that junk back onto the paint surface and risk scratching it. Load up your wash mitt with your car wash solution and wring it out over the wash surface. This acts like a “pre-soak” and helps loosen surface gunk. It also adds more sudsy water to the surface more lubricity to help safely wash the grime away without scratching. Keep your wash areas small and rinse your wash mitt frequently in the second bucket. Wash in straight, overlapping lines as opposed to circles and remember to be gentle with the wash mitt on the first pass. This first pass will pick up the majority of the dirt, and loosens the remaining dirt for pick up on the second pass. Rinse your vehicle by opening up your Fire Hose Nozzle to the open flow setting or by removing the nozzle if you don’t have an open flow option on your nozzle and let the water run or sheet over the surface instead of spraying. This helps in two ways. First, generally when water has “sheeted” off of a surface it tends to leave less residual droplets behind. This means less to drying time. Second, since there is less water to pick up, there is less chance of your leaving water behind to “spot” the vehicle. When you dry your car, use only high quality microfiber waffle weave drying towels and wring out often. Gently dry the surface without much pressure. You don’t need to rub the surface…you’re just picking up the bulk of the water! Once you have picked up the bulk of the water, and the first towel is saturated, use the second towel to lightly pick up any remaining streaks or droplets. Lastly, if your wax or sealant is still in good shape, go over the vehicle with a quick detail spray like or Sonus Acrylic Spritz Detail Spray or BLACKFIRE Midnight Sun Instant Detail Spray and a plush Cobra Deluxe Jr. Microfiber Buffing Towel to restore a radiance and slickness to the paint. This last step will give your vehicle that “just detailed” look by enhancing gloss and will also remove any missed drips, water spots or streaks that showed up when you weren’t looking. |
04-27-2012, 01:08 PM | #11 |
Voice Of The Voiceless
A lot of great info here! Thanks!
04-27-2012, 03:24 PM | #12 |
Drives: 2014 Ford Focus ST Join Date: Jun 2009
Don't forget that a leaf blower is another option that helps you in drying your ride and keep you from putting more swirls on it. Also take a look at the Metro MasterBlaster 8hp system. This baby will deliver 58,000 feet-per-minute of clean, dry, warm, filtered air. Each motor is controlled by a separate switch that allows you to select from three different airflow and temperature levels and what's left are maybe a few drops coming from the gas cover or some hidden area and use your WW towel to dry.
04-27-2012, 04:41 PM | #13 | |
Drives: '11 Camaro 2SS/RS LS3 Join Date: Jan 2012
04-27-2012, 04:46 PM | #14 |
Drives: 2010 Victory Red SS Join Date: Apr 2012
I have a Master Blaster, well worht the money
Similar Threads | ||||
Washing/Detailing for Newbies | MRK III Z28 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 125 | 02-05-2024 09:55 PM |
Help! Dealership put swirl marks in my paint and has refused to fix them! | Alarick | 5th Gen Camaro SS LS LT General Discussions | 103 | 02-01-2011 06:53 AM |
Destroyed my paint job | HotBody | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 38 | 11-23-2010 06:54 PM |
Removing Swirl Marks using a Flex and Meguiars M105/M205 | Angelo@Autopia | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 5 | 05-22-2010 10:36 PM |
Car Washing.................... | Angelo@Autopia | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 5 | 03-08-2010 06:48 PM |
