Old 03-07-2015, 11:03 AM   #1
tadams72
When is enough ever...
tadams72's Avatar
Drives: 2006 Silverado 2500HD CC/SB LBZ
Location: Residence: Chula Vista, CA Home: Billings, MT
Thumbs up LS3 Parts For Sale from 2011 Camaro
I've got some parts from my 2011 LS3 that I am letting go as I won't need them on the new build. Shipping at buyers expense.
Full disclosure, all parts came out of my 2011 Camaro SS LS3. I had a valve spring failure on the number one intake valve that floated the valve into the piston. That piston is toast as is the cylinder head from that side. The engine never lost oil pressure (I was data logging the time so I know this to be fact). The engine had 9900 miles on it at the failure and had no less than 4 oil changes in that time. I only ran Mobil 1 5W30 full synthetic and I had the rev limiter set to 6350 so aside from the spring failure everything was extremely well taken care of. You can see some of the #1 piston did migrate through the intake to the other cylinders.
While some of the pistons may require a little cleanup and the valve seats should be checked as well, the bearing surfaces on everything look good visually and you can't snag a nail on anything. Minor scuffing on piston skirt coating but not abnormal. Pistons should clean up nice and the rods look perfect. Cam was awesome but probably not the right style for the HPDE events I was doing. Vengeance made 460+ rwhp with this cam and other mods. Noticeable lope. Really liked the attitude of the car with it.
A little video from before the spring failure. Cam was awesome!
http://youtu.be/vDyWgz0aeso
So if you are doing a stock or mild rebuild, these parts will save you some money.
(1) Stock LS3 intake manifold. - $100
(1) Stock shifter assembly. - $100
(4) Stock sway bar end links. - $50
(1) Intake manifold insulator. - $25
(8) Stock plug wires. - $20
(1) Engine Cover - $40
(1) LS3 Oil Cooler and Lines (no leaks) - (Sold)
(16) Comp Cams 5/16" .080 wall 7.4" hardened pushrods. - (Sold)
(8) Stock LS3 fuel injectors. - (Sold)
(1) LS3 Crankshaft (58 tooth reluctor) - (Sold)
(1) LS3 (0821) cylinder head. Complete with valves, seals, TEA double springs, titanium retainers. - (Sold)
(1) PowerBond 25% under drive balancer. - (Sold)
(7) LS3 Pistons with pins - (Sold)
(8) LS3 Rods - (Sold)
(1) Vengeance Racing Stage 2 Camshaft and LS3 Roller Lifters - (SOLD)
3 bolt, 227 int / 239 exh, .612 / .612, 112+3
Stock LS3 Clutch (2500 miles when removed) - (SOLD)
If your interested in any particular item and want more info, shoot me a PM. Happy to take additional pics, shoot some short video footage, or FaceTime for you to see the part in question.
Thanks for looking!
The Project: 2011 Camaro 2SS/RS (ERL 427 Superdeck NA Monster)
"Just like farmer engineering. Find the weak link and fix it, then find the next one." Salt Cat Racing
tadams72 is offline   Reply With Quote
Old 03-08-2015, 08:20 PM   #2
lsxrx7
Drives: ls1
i'll take the clutch set
sent u a PM
lsxrx7 is offline   Reply With Quote
Old 03-08-2015, 08:28 PM   #3
45thCAMARO 2SS/RS
xquest91x
45thCAMARO 2SS/RS's Avatar
Drives: 2012 45th Anniversary 2SS/RS
PM'D you
2012 45th Camaro 2SS/RS LS3
Driver Mod: Stage 5
Full Bolt-ons + Tune •418RWHP/420RWTQ•
H/C + Bolt-ons + Tune •485RWHP/435RWTQ•
Full BMR Stage 2&3 Suspension
3.91 1LE Gear Diff Swap
MGW Short Throw Shifter
45thCAMARO 2SS/RS is offline   Reply With Quote
Old 03-09-2015, 01:47 PM   #4
laurentj23
Drives: s14 swapped vq35
Do you have the timing cover?
Valley plate?
laurentj23 is offline   Reply With Quote
Old 03-09-2015, 03:41 PM   #5
mombo390
mombo390's Avatar
Drives: 2014 SS 1LE Non-RS w/NPP & Recaro
was the stage 2 cam ever installed?
Loan Officer at Allied Lending Group, Inc.
Current Rides: '14 Camaro 1SS 1LE, '04 Lexus LS430
Life's Too Short To Drive Boring Cars!
mombo390 is offline   Reply With Quote
Old 03-09-2015, 03:55 PM   #6
KW Baraka
KW Baraka's Avatar
Drives: 2014 Chevy SS
Complete LS3 fuel rails with crossover tube?
Thanks!
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4
2014 Chevy SS --- 429ci Hydraulic Roller LS3
KW Baraka is offline   Reply With Quote
Old 03-09-2015, 08:10 PM   #7
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
I'll take the pair of the heads
Nightmare2012 is offline   Reply With Quote
Old 03-09-2015, 10:03 PM   #8
tadams72
tadams72's Avatar
Just one head. The other was damaged when it dropped a valve.
Old 03-09-2015, 10:04 PM   #9
tadams72
tadams72's Avatar
Nothing else for sale other than what is listed above. I've got a few people lined up on some of the items so far.
Old 03-10-2015, 11:57 AM   #10
lxinms
Drives: 2001 Camaro SS & 2005 Canyon ZQ8
Let me know if I'm the one who has dibs on the cam. I'd rather yours, but if it's not available I've found another.
lxinms is offline   Reply With Quote
Old 03-11-2015, 01:39 PM   #11
tadams72
tadams72's Avatar
Bump. Some tire kickers and one buyer so far. Thanks.
Old 03-11-2015, 05:48 PM   #12
baggins
Drives: 65 mustang
Ill take the pistons and rods. Text 9167518861 please
baggins is offline   Reply With Quote
Old 03-12-2015, 09:08 PM   #13
tadams72
tadams72's Avatar
Rods are sold. Cam is pending. Bump for some good stuff remaining at a great price.
Old 03-13-2015, 04:11 AM   #14
AquaRSSS
AquaRob
AquaRSSS's Avatar
Drives: ABM RS\SS; 69 427 Camaro; 1970 Z28
Did the clutch and flywheel sell?
Centerline, Weld, Holley, Nick Williams, GMPP, Diamond, ARP, Callies, Nelson Racing, Pro Torque, Strange, J&S Polishing, RMCR, AAC, MBRP, Flowmaster, FAST, Comp Cams, RX Performance, Aeroquip, Spectrum Powder-Coating, Current Performance, RX,TDub Racing, DSS, Fore Innovations, Aeroquip, Earl's, BMR, Ximpac, MPD,Street Scene, Blood, Sweat and Tears
AquaRSSS is offline   Reply With Quote
