01-11-2015, 09:47 AM | #1 |
Drives: '14 RRM 1LT/RS A6 Join Date: Mar 2009
Bought 08/11//14, should my cabin filter be this gross?
The air quality inside the car is completely different now.
I complained to the dealer when I first bought the car that it smelled like construction zone (they built the dealership with cars on the lot getting smothered in dust) inside the vehicle w/ the HVAC system running. I told them to replace it. They ozonized it or w/e, said the part was a special order and they didn't have any in stock. So I said f them. Fast forward 5 months (16000 miles) and I finally replaced it myself. Can't believe I was breathing that shit in. Pic coming.. Last edited by Splitter; 01-11-2015 at 10:08 AM. |
01-11-2015, 10:01 AM | #2 |
Jumanji
Drives: '14 Z/28 - AGM - No A/C Join Date: Mar 2014
IIRC that filter gets drawn through with the system on. Otherwise just sitting there it would not accumulate that much junk. Glad you got it changed, i too like fresh air!
01-11-2015, 10:05 AM | #3 |
Drives: 2012 Camaro 2SS/RS Victory Red Join Date: Jun 2014
I've been thinking about changing mine or at least checking it.
Just a side note: That's what was caught so you didn't breath that particular shit in.. |
01-11-2015, 10:06 AM | #4 | |
Do you mean battery compartment in the back? |
01-11-2015, 10:07 AM | #5 |
01-11-2015, 10:32 AM | #6 |
MY SS is SOLD
Drives: AGM 2012 Camaro 2SS/RS L99 Join Date: Mar 2012
What's your engine air filter look like after 16k miles?
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
01-11-2015, 10:40 AM | #7 |
01-11-2015, 11:25 AM | #8 |
Drives: 2020 GMC Sierra AT4 Join Date: Jul 2013
I should change mine. Don't know when it was last replaced.
2023 Camaro 2SS 1LE Summit White
1100 - 3/23/2023 2000 - 3/27/2023 3000 - 3/28/2023 3400 - 4/12/2023 — 4/24 TPW 3800 - 4/28/2023 5000 - 5/30/2023 6000 - 6/03/2023 2020 GMC Sierra AT4 6.2L Black |
01-11-2015, 11:33 AM | #9 |
Drives: 2011 Camaro 2SS/RS Join Date: Jun 2011
I've seen a few other posted pics of original cabin air filters and i bet the first one has some sort of coloration that makes it look like that. My 1st filter looked exactly like that too. It's like a charcoal color, it might give filtered air a better smell instead if a musty filter scent.
01-11-2015, 12:19 PM | #10 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
op that is not flood damage....if the filter was wet the material would be broken down a lot more . That's just dust and dirt.
01-11-2015, 12:59 PM | #11 |
My Jag uses carbon filters and they look just like that. I bought a replacement filter for the Camaro when I replaced the other and it was white just like the one it came with. I haven't changed it yet as I only have about 7,000 miles on the Camaro. While I was searching I found you can get just about any filter with the carbon impregnations if you want to pay for it.
The OPs filter looks like it was changed with a carbon one. Or perhaps GM is install them now.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
01-11-2015, 01:13 PM | #12 | |
01-11-2015, 02:15 PM | #13 |
ace5.org
My filter looked the same when I changed it. Nothing to worry about. Just an option--I ordered mine off amazon for less than $15 and had it here in less than 2 days.
Stock...For Now.
