10-25-2013, 10:11 PM | #1 |
vortech from another car?
so my friend has a vortech for his 2012 5.0 and is soon going to upgrade to a procharger. i was wondering if id be able to take his vortech and just get the mounts for a camaro? i know the piping wont work but just wondering if the blower its self is universal?
2011 camaro RS/SS M6 (weaponX) CAI Cold Air Intake, american racing LT headers, x-pipe, high flow cats and full 3inch exhaust, Cam, VDP Tune. |
10-26-2013, 01:38 AM | #2 |
The Man in Black
Drives: 1969 Camaro 2010 Camaro 1SS Join Date: Apr 2009
I'd search the part number if the camaro kits the unit might be able to be used but I'm not sure
10-26-2013, 09:46 AM | #3 |
Make your peace with God!
Drives: 2011 Camaro SS/RS M6 Convertible Join Date: Dec 2011
Not too sure. If he's running a CW rotation, you probably can. You just might have to loosen the bolts on the volute and rotate it. If he has a CCW rotation, you're out of luck. But the best thing to do is get his part number, give Vortech a call and see if it's a matching part number to a camaro.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ UNDER MAJOR OVERHAUL!! |
Thread Tools | |
