06-14-2011, 10:19 AM | #1 |
Burning up tires
Drives: 2023 ZL1 Vert Join Date: Jul 2010
Oil Leak
When I got my car out of winter storage (6 months) there was a puddle of oil on the garage floor about 6 inches in diameter. There was also oil residue on the oil pan and on the bellhousing. Since then, I changed the oil and filter and cleaned up the oil residue. I looked under the car again today and sure enough there are signs of oil.
I can't tell if it is comming from the pan gasket, oil cooler, or rear main. The car only has 2600 miles on it and sits in the garage most of the time. If it is just the oil cooler gasket I would just assume fix it myself, however if it is the pan gasket or rear main, looks like I have to bring it to the dealer. Here are some pics: There is oil around the cooler, a drop on the bellhousing, and film on the oil pan itself. Last edited by ITGuy11; 07-12-2011 at 10:51 AM. |
06-14-2011, 11:17 AM | #2 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
Looks like mine except for that last picture. My passenger side at the back of the oil pan is dry, only wet at the left rear in/around the filter area. Appears to be coming from above the oil cooler, my guess is oil pan gasket, but won't know until the dealer tears into it. I've got an appointment to bring it in tomorrow morning. They're also changing out the AC belt for intermittent squeak.
06-14-2011, 04:15 PM | #3 |
2010 RS 2SS
Mine looks exactly the same, will be taking it in for a check please post what they find with yours when it is done.
K&N, MBRP exh. , Hurst, PEDDERIZED with drops/bushings, Chrome bumpers, retro hood vents, ACC marker tinted marker lights, and soon to have chrome rocker trim. Working on 20" custom rally rims next, then onto the supercharger. |
06-14-2011, 06:32 PM | #4 |
Drives: SuperCharged 2SS/RS IOM MN6 Join Date: May 2009
the oil cooler gaskets definitely need to be replaced. the oil pan gasket may be leaking as well. I hope you rear main seal is ok and you don't have the engine rear cover porosity issue. These 4 issues are known issues.
06-14-2011, 08:55 PM | #5 |
Born: August 27, 2009
Drives: 10CAMARO SS,12CRUZE RS,07 YAM R6 Join Date: Aug 2009
can you smell oil burning when sitting for a bit....i changed my oil and since then i can smell a bit burning. i did notice a little oil on the bell housing when doing it.. i just havent had it back on the hoist to look yet,,,but maybe mine looks like yours too...
Victory Red 2SS/RS
Vin# A9130145 |
06-15-2011, 12:50 PM | #6 | |
Burning up tires
06-15-2011, 01:33 PM | #7 |
Drives: 2014 Impala Join Date: Feb 2009
Had the same problem the first fall (2009). Dealer replaced the oil cooler but that didn't fix it so they replace the entire oil pan in the spring. Been dry every since.
Ordered on 10-14-08 - Silver Ice Metallic/Black Leather 2SS/RS, 6 Spd, Sunroof, Polished Wheels. Build date: 04-17-09, VIN 3978, Delivered 04/29/09! Sold on 04-16-2012 :(
ZL1 Ordered on 10-29-11 - Silver Ice Metallic, 6 Spd, Sunroof, Polished Wheels, Exposed Carbon Fiber Insert. Build date: 05/17/12, VIN 1415. Delivered 05/30/12!!!! Sold 05/28/12 |
06-15-2011, 02:09 PM | #8 |
雪の玉
Well picking up my SS after work today. Said they replaced the oil cooler gasket. Fingers and toes crossed that's all it was. I'll give it a couple of days and check it again.
06-16-2011, 09:10 PM | #9 | |
Burning up tires
I cancelled my appointment with my dealer. I am going to replace the oil cooler gasket myself and see if that fixes the leak. If not, I will bring it in. I hate the thought of anybody but myself wrenching on my car... |
06-16-2011, 11:13 PM | #10 |
Drives: 2010 IOM 2SS Join Date: Jul 2009
I had the same puddle under mine, but it ended up being the oil filter being a little loose. Some dumba$$ didn't tighten it down enough when I...er, he changed the oil
So many projects... so little time.
2010 2SS, IOM, IOI, CGM stripes, L99 1999 Astro van, LS 1995 Saturn SC2 1994 Saturn SC1 1992 Saturn SL2 1991 Daihatsu HiJet 1981 C10 Beater, with a heater, er..A/C 1973 Nova SS, 385 stroker, TH400, FOR SALE! (soon) 1966 Suburban, LS bound! Still in a million pieces 1965 C-10, Short, Wide, Big window, all roller 355 |
06-17-2011, 09:31 AM | #11 |
雪の玉
They tried to use that excuse on me last week when I first brought it in. I knew it wasn't going to be the fix as oil doesn't leak upward.
06-17-2011, 09:38 AM | #12 | |
雪の玉
IMHO, judging from your pictures, with your passenger side being wet as well, yours may be a bit more involved. ie. oil pan and or the rear cover/rear main seal (tsb 05-06-01-034L for the rear cover/seal block porosity issue). Those are not easy and may want to still bring yours into the dealer. Last edited by nancygrl; 06-17-2011 at 11:01 AM. |
06-18-2011, 11:17 AM | #13 |
Drives: 2013 Sea Ray 220 Sundeck Join Date: Apr 2011
I had this same problem the dealer fixed it right away. The oil pan gasket was leaking GM is known for using shitty gaskets at the factory and since the SS uses synthetic oil it finds any tiny little hole and leaks out because its so thin.
Dealer put on a new gasket and cleaned up the mess on the undercarriage for me(which was not that bad)
It's not who you are underneath but what you DO that defines you
06-21-2011, 07:56 AM | #14 |
雪の玉
Well, it's back to the dealer for me tomorrow. Guess I had more than just the oil cooler gasket leaking. This f*@king sucks
Similar Threads | ||||
First oil change? | Fogey | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 27 | 09-18-2010 06:50 AM |
My oil leak wasn't an oil leak.... | yzfmik | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 7 | 05-10-2010 01:17 PM |
synthetic motor oil? | bigd1276 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 71 | 01-29-2009 12:28 PM |
Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 09:47 AM |
