10-06-2012, 01:08 PM | #1 |
Russ
Tracking down rattle from new sub install.
I had a new 12" Rockford 1100 watt subwoofer/amp installed in my trunk. It sounds great but at certain bass levels I will get a lot of rattling sounds inside of the car. I have been trying to track them down but no luck. Does' anyone on the forum have any suggestions on how to track down these rattles so I can fix them?
Russ |
10-06-2012, 07:20 PM | #2 |
Car nut
Drives: Tahoe Z71, Race cars Join Date: Aug 2010
There's a common problem with the rear deck making noise. Do a search on here for threads.
Otherwise, I'd just climb in there with it playing and just press on panels here and there until you narrow it down.
Quote: Don't you just hate it when Satan steals your ride and does all these weird ass mods to it?
R.I.P. Evan .. A true Friend |
10-07-2012, 02:00 PM | #3 |
Go here and download a couple test tones and put them on a flash drive. If you run a 10-100Hz sine sweep, you will hear which freqs are causing which rattles. Then you can play a sine wave for that specific freq and find the rattle.
The test tones are great, because you don't have other noises drowning out the rattles. |
10-07-2012, 03:15 PM | #4 | |
Russ
Russ |
10-07-2012, 04:19 PM | #5 |
I had the same issues, I used FatMat, not Dynamat. I got it on Amazon for 45 bucks for 25 square feet. I did the back deck, the sides, under the rear seat and both my doors, and the trunk lid. It took care of all the rattles. I have used about 40 square feet. http://www.amazon.com/FatMat-mill-Bu...eywords=fatMat
10-07-2012, 06:58 PM | #6 | |
Russ
10-07-2012, 10:08 PM | #7 |
Voice Of The Voiceless
I get rattles from the rear deck, and sometimes even from the rear view mirror Eventually, I'll have to add some sound deadening
10-08-2012, 08:50 AM | #8 |
Drives: 2006 F150 Lariat Join Date: May 2010
Something in my undercarriage rattles horribly. It's not my exhaust and it's not my trunk. I don't think I can fix it myself...
10-08-2012, 11:15 AM | #9 |
Drives: 2010 camaro 1ss Join Date: Aug 2012
Gonna check that out. Im getting sick of all the rattle in mine.
10-08-2012, 11:50 AM | #10 |
They call me captain slow
Drives: 2010 camaro lt Join Date: Jun 2010
How hard is it to remove the rear seat and paneling
10-08-2012, 12:25 PM | #11 |
10-08-2012, 12:45 PM | #12 |
Hating prius's since 1997
Drives: 2010 Camaro 2SS/RS (JENNA) Join Date: Apr 2011
I sound deadened my trunk, rear deck, under back seat and sides. I only have 1 rattle under certain bass tones as you. I believe I have narrowed it down to one of the clips that is on the panel that covers the airbag. I believe its the little slide clip that mite have came undone.
PIPE
10-08-2012, 12:59 PM | #13 |
I didn't do it all in one session. I did the trunk in about an hour, the doors took me about 2 hours. And the back seat and sides took me about 3 hours to do, but I enjoy working on my car and it is fun for me. So I have 3 sessions into it and it got rid of the rattles.
10-08-2012, 01:55 PM | #14 |
I have a rattle in my overhead console that is beyond frustrating. I have taken it down several times, and still cannot eliminate the rattle. I've Dynamated everything, and even used Dynaliner.
