09-03-2017, 01:36 PM | #1 |
Drives: 2018 ZL1 Summit White M6 Join Date: May 2017
Front end suspension issue, need help!
Hello all,
Here's the situation, randomly something in my front end (sounds like loose struts to me) will start making noise when I go over bumps. Primarily on the driver side but sometimes passenger as well. It will get worse and worse as I drive, then it will just go away and back to normal??? Took it into the dealer but since they couldn't hear anything at that time they think it was possibly a rock got caught in my suspension or something but it keeps coming back periodically. Any thoughts what this may be or have any of you experienced something similar? Thanks in advance! |
09-03-2017, 01:40 PM | #2 |
Drives: 2017 ZL1 A10 Join Date: Jul 2014
Check and re-torque swaybar end links.
09-03-2017, 02:50 PM | #3 |
Tony
Drives: 17 ZL1 Join Date: Nov 2015
Took mine in Friday and they told me my swaybar end links need to be replaced. Awaiting parts.
-Tony
09-03-2017, 03:04 PM | #4 |
I love crepes
Very common issue with sway bar nuts coming loose. There's a TSB. Call your dealer and take it in for a quick fix.
09-03-2017, 04:53 PM | #5 |
Drives: ///M3 Join Date: Nov 2016
Just install NordLoc washers and be done with it.
09-03-2017, 05:04 PM | #6 |
Makes sense thank you all for the info, headed to the dealer tomorrow!
09-03-2017, 06:45 PM | #7 |
Drives: Camaro ZL1 2018 Join Date: Aug 2017
Same problem zl1 2018. Mostly driver side not always this clubky noise. The dealer said that 2018 changed the system and is not this problem anymore...they adjusted everything but sometimes happens the same. Now has 500 miles with with 1,500 oil change after break in I will claim again. does anyone know if really 2018 ZL1 had some change or is a fake speech from dealer??
09-04-2017, 02:44 AM | #8 | |
Drives: X-15 Velocipede Join Date: Mar 2008
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer STANDARD DISCLAIMER camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever, whether express, implied, or statutory, including, but not limited to, any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free. |
09-04-2017, 08:29 AM | #9 |
Do you happen to know the tsb number for this issue? I gave the ol google a look but couldn't find anything. Just want to go in armed with all the info incase they try to give me the run around...
09-04-2017, 08:31 AM | #10 |
1959 Chevy Apache 4X4
Drives: 2017 ZL1 Join Date: Feb 2016
took mine in last week. I had to print the bulletin from this website. Dealer couldn't find it. I see where others have had it done while they wait. Mine wanted to keep it....over the holiday
ugh
2017 ZL1 garnet red/A10/nav/pdr/sunroof/CF hood insert
1100 2-1-17 2000 2-14-17 3000 2-15-17 3000 TPW 3-13-17 3300 3-6-17 3800 3-13-17 4B00 3-13-17 4200 3-15-17 4800 3-22-17 5000 3-27-17 6000 3-28-17 |
09-04-2017, 08:34 AM | #11 |
Stella, do you happen to have a link to that info? I'm going in today and need it asap!
09-04-2017, 09:10 AM | #12 |
Found it! Incase anyone else needs it...
http://www.camaro6.com/forums/showth...r+loose&page=4 Post #56 |
09-04-2017, 10:33 AM | #13 |
sorry whiteboy18. I stepped away for a sec. I'm glad that you found it
09-04-2017, 03:17 PM | #14 |
