10-22-2013, 02:21 PM | #1 |
Jim
Drives: 2013 Black 2SS 1LE Join Date: Apr 2013
Underhood insulation help
Okay guys here are the questions?
How do I clean the under hood insulation on my Camaro? What can I buy that will go on top of insulation and be easy to clean. Something simple yet classy. I have a 1LE. Where can I find them? Jim |
10-22-2013, 02:33 PM | #2 |
KaBoom1701
Use a vacuum?
Mods:
10-22-2013, 03:45 PM | #3 |
100% Chevy & Harley Man
Drives: 2010 2SS: Blown LSX 376-B15 Join Date: Feb 2009
I put on a fiber glass custom hood. Not because of dirtiness; I needed a little more space for the Maggie. But if your insulation is getting dirty, having a smooth fiberglass finish will help keep it clean easier! I never ride mine in the rain/snow, so mine never gets dirty.
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers w/ Trunion Bearings, ATI Balancer/keyed, AR LT Headers/Borla Catback Exhaust, DSS 1400 HP Axles, DSS aluminum driveshaft, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)w/ Hidden Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
10-22-2013, 11:52 PM | #4 | |
Jim
come on guys
Look I know it is not the most interesting thread, but I still need help. Jim |
10-23-2013, 08:16 AM | #5 | ||
High-tech Redneck
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8 Join Date: Nov 2010
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning. |
10-23-2013, 08:33 AM | #6 |
Drives: 2 LT/RS YELLOW, AUTO., VIN NO. 602 Join Date: May 2010
Here's what I did.
Soft finish, easy to clean and affordable. http://www.acscomposite.com/project/...05&id=26359254
10-23-2013, 09:02 AM | #7 |
Drives: too many Join Date: Jul 2013
plastidip it?? jk.. this "Carpet cleaner and a soft bristle brush. Don't fuzz it up by rubbing too hard, but just enough to loosen the dirt. You may then be able to respray with the cleaner and wipe it down with a terry cloth rag."
10-24-2013, 11:36 PM | #8 |
Drives: Black ZL1 Join Date: Apr 2013
Why doesn't the ZL1 have insulation and the others do? Because the ZL1 hood is aluminum? I really prefer not having it, glad I don't. Wonder how a LS/LT or SS would do without it?
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
10-24-2013, 11:56 PM | #9 | |
Jim
I was told
Wait a minute, I was told my 1Le hood and perhaps all the Camaro SS hoods are aluminum. If that's true, why can't I remove it or will it hurt the wrap? Jim |
10-25-2013, 04:53 AM | #10 |
Drives: CGM 2SS/RS, 1987 & 2014 Silverado Join Date: Oct 2010
All Camaro hoods are aluminum and the insulation is also a fire blanket designed to drop in the event of fire and try to smother the flames. I clean my insulation with a damp towel. The new Silverado hoods are aluminum as well.
10-25-2013, 03:12 PM | #11 |
How about the '14 SS's? Do they have the insulation? I ask, because if the ZL1 doesn't, maybe it has to do with the extractor, and therefore how does that effect the new hoods with extractors? Anyone
10-25-2013, 04:27 PM | #12 |
Drives: 14 1LE Join Date: Mar 2013
My '14 1le has the insulation. I've always just hosed it off with water.
LMS Engineering
10-25-2013, 08:02 PM | #13 |
Drives: 2010 Camaro 2SS/RS Join Date: Dec 2009
This Is what I do also. I have a foam gun, and when it is dirty I soap and rinse it clean, then leave the hood up till it dries. Looks brand new.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10. ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller. |
10-25-2013, 08:38 PM | #14 |
Drives: 2010 Camaro Join Date: Dec 2009
They are both Aluminium. Removing the hood liner is not an issue if you are referring to paint durability or damaging the hood.
The OEM insulation is designed to cut down engine noise and keep cabin sound in to what is intended. No doubt the aluminum and paint system is made to withstand any possible heat that can be generated from the engine. On another note, if you are looking for alternatives, we have designed a replaceable hood liner made in 2.5 mm RTM material, is paintable, and can be ordered with optional LED's More info @ ACS WebLink |
