01-21-2013, 11:42 AM | #1 |
3.25 to 3.45 Gears
Alright so my buddy just swapped out his 3.45 rear end in his LS3 and put the 1LE rear end in with 3.91. My question is since he has the entire rear end with 3.45's in it would it be worth it to swap my 3.25 (L99) for a 3.45 rear end. Would I see any noticeable difference in track times or would it not be worth doing? And my track times I mean 1/4. Btw my car is a auto L99
Mods: "Cam Only"
01-21-2013, 03:07 PM | #2 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Yes, do it. Just need to flash in the ratio change for the speedo.
You will love it. (then PM us and we will buy your 3.25 unit to put 3.91's in). |
01-22-2013, 01:07 AM | #3 |
Alright thx. I will definitely send u a pm about my 3.25's . Any idea what I can expect to gain as far as better ET's and trap speeds?
Mods: "Cam Only"
01-22-2013, 08:13 AM | #4 |
I went from 3.45's to 3.70's in my LS3 SS and it was perfect, just that small ratio change made a world of difference. A change from 3.27's to 3.45's in an auto L99 would be a similar jump. You will need a tune for the speedo and odometer as stated in an above post.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
01-22-2013, 09:42 AM | #5 | |
Mods: "Cam Only"
01-22-2013, 01:46 PM | #6 |
Drives: 2010 2SS/RS Red Jewel L99 Join Date: Jun 2011
I just did mine today. From 3.27 to 3.45
Can't try it though.... due to weather. |
01-22-2013, 01:51 PM | #7 |
Nice, well whenever the weather improves and you can take it for a spin yet me know what you think..
Mods: "Cam Only"
01-22-2013, 02:39 PM | #8 |
With the A6 trans the jump is pretty ideal. Expect as much as .5-1 tenth gain in the 1/4 mile.
01-23-2013, 07:32 PM | #9 |
Drives: 2010 2ss 6 speed Join Date: Apr 2011
3.70
flht99b
I went from 3.45's to 3.70's in my LS3 SS and it was perfect, just that small ratio change made a world of difference. A change from 3.27's to 3.45's in an auto L99 would be a similar jump. You will need a tune for the speedo and odometer as stated in an above post. Ed M. --------------------------------------------------------------------- Ed M I ordered my 3.70 with the eaton trutrack from jre plus extras. tell us more about what you like |
01-23-2013, 07:48 PM | #11 |
New product
20x11 wheels with 315/35/20 studded tires for maximum winter traction. lol......... -30 c = -22 F It's been a cold week for sure.......... |
01-23-2013, 08:10 PM | #12 |
Drives: 2010 ZR1 Camaro Join Date: Dec 2012
I swaped my wifes and it really woke the car up,i had a tune at the same time but i really like it.
01-23-2013, 09:01 PM | #13 |
CamaroFans.com
Nice to see Hendrix is back.
01-25-2013, 10:39 AM | #14 | |
Ed M.
