04-04-2022, 04:19 PM | #1 |
Drives: 2018 2SS 1LE Join Date: Sep 2021
BMR Cradle Lockout and Diff Lockout
2018 SS 1LE
I have the BMR BK063 Cradle lockout getting ready to install, I have bought 4 new tty bolts after researching, while researching I read that some people say the diff lockout BMR BK060 is not needed while the cradle lockout is the one I want, so does anyone have both? Do I need both? Figured since I’m doing the lockout I should do the diff as well. Also there is a TTY bolt for the diff lockout but I’m having trouble finding that on the GM parts website. Thanks in advance! |
03-12-2024, 07:47 PM | #2 |
Drives: 2023 Camaro ZL1 Join Date: Jan 2023
A good question you asked. Surprised you did not get a response. I am also curious to hear from others experience. Technically the TTY bolts should be replaced but BMR reused old bolts with no negative effects. The four bolts for the rear cradle lockout are available for under $5 each.
2023 Camaro ZL1 6MT Summit White
03-12-2024, 08:07 PM | #3 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
I’m running both kits. Reused the bolts. Been running those for 4 years or so, no problems.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
03-13-2024, 06:38 AM | #4 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I did not see the need to do both and only did the cradle lockout, reused the bolts but I did have to buy a torque angle dial indicator for my torque wrench. I did do the front of cradle braces because those were an economical and easy install option.
03-13-2024, 08:01 AM | #5 |
If you start making decent power you’ll want the diff lockout too…
03-13-2024, 07:13 PM | #6 | ||
When you guys did the rear cradle lock out, did you find the need to get a suspension alignment? BMR mentions to get it done, but I find it hard to believe the alignment would change. Thanks.
03-13-2024, 09:47 PM | #7 |
I did not, but I also did the BMR rear toe arms not long after and that obviously required an alignment. So while I believe I was fine without the alignment, I didn’t run it that way long enough to say for certain. Sorry!
03-14-2024, 07:23 AM | #8 |
I didn't get an alignment as I didn't do anything to warrant it with the cradle lockout.
03-14-2024, 08:55 PM | #9 |
Thanks for the response to both of you. I did not think an alignment was necessary.
03-15-2024, 07:59 AM | #10 | |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
I did get an alignment on my 2017 SS and it was out of spec after the BMR install. |
03-21-2024, 09:39 PM | #11 | |
03-22-2024, 12:50 PM | #12 |
Drives: Nickey Super Camaro Join Date: Nov 2008
Once you get it on the alignment rack you will know whether or not an alignment was needed. If all is within spec a reputable performance shop will not charge you to align if not necessary, when it takes 10 min to check.
03-22-2024, 01:16 PM | #13 |
Drives: 2020 1SS 1le Join Date: Apr 2019
It needs an alignment. That should be end of question. I barely moved mine down for the real cradle lockout and it was off once we got it on the rack. Felt much better. I would also def replace those bolts. Its cheap assurance and they are easy to get. Idk why its much of a question
03-22-2024, 01:39 PM | #14 | |
Drives: 21 SHOCK ZL1 M6 Join Date: Sep 2023
Tags |
bmr, cradle, cradle lockout, diff lockout |
