03-13-2014, 12:59 PM | #1 |
Drives: 2011 Camaro 2SS Join Date: Sep 2012
600 HP, Reliability and Driveability
Hey guys,
This summer I am wanting take my car to the next level. I was originally wanting to just supercharge, had thought strongly on the LSA supercharger. Now, I am thinking that I may cam as well. This would probably clear the 600rwhp mark relatively easily I'd imagine, I dont think I would want to go much higher than 600. I am pretty new to car modding, so any advice would be appreciated! So my question is, what do you think I will need upgrade motor wise? All forged bottom end? Crank, pistons, rods? What else? anything drivetrain wise? Following that question, Those of you with around 600rwhp, whats your driveability like? Thank you in advance!
2011 Camaro 2SS/RS LS3 M6 - 672rwhp/581rwtq - 91 octane tune
03-13-2014, 08:43 PM | #2 |
Sold car...
Drives: 2010 Rally Yellow 2SS/RS #37115 Join Date: Oct 2009
I'm over 600 on a conservative tune with stock bottom end, but did a ECS blower cam and valve springs and retainers with a LS3 conversion. The transmission is holding up well with a vigilante 2800 stall and 3:45 rear end has JRE posi mod and caps. So far so good. Drivability is not at all bad. It takes a but more to start off slow since the converter was put in but other than that unless I go a bit hard on the throttle it's fine. Plus the BOV sounds awesome. I would only worry about axles and rear end at 600hp. Wheel hop will destroy parts.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust. |
03-14-2014, 11:11 AM | #3 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
I'm at 546/rwhp with E-Force S/C and no cam. See my sig for the rest of my mods. Drivability is very good. My experiences with a cam have been that you loose some drivability. It all depends what you are looking for.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
03-14-2014, 11:49 AM | #4 |
Echale Gas [COTW 3/10/14]
Drives: 2010 Camaro SS/RS Supercharged Join Date: Aug 2010
502rwhp here. Drives like stock and 85,000 miles so far no issues other than just changing out tensioner pulley
Kenne Bell 502 rwhp/ 471 rwtq at 9psi (daily driver...for now) Performance: Corsa catback, JRE Super Tensioner, dual pass heat exchanger, R1 slotted & Dimpled rotors cryogenically treated Cosmetic: Giovanna kilis 22", zl1 mailslot bumper, Custom Emblem Pro Badge, painted calipers |
03-14-2014, 12:43 PM | #5 |
Drives: 2010 Camaro SS Join Date: Oct 2013
I am at six and a quarter running 8 psi. Driveability is good. A little body shake at idle with the cam but I like it!
Stock bottom end with Brian Tooley's Platinum springs and pushrods. Seems plenty reliable and I drive it HARD!
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
03-14-2014, 01:48 PM | #6 |
Drives: 2011 2SS Convertible Supercharged Join Date: Nov 2010
I will be right around 600 rwhp when I finish getting my cam in. Car drives like stock till you floor it. Mods in sig.
03-14-2014, 01:54 PM | #7 |
"Go on the last yellow.."
Drives: 2010 2SS/RS L99 CGM Join Date: Jan 2010
We have 600rwhp with an LS3 conversion, FTI converter, Whipple, ID injectors, Duel LPE fuel pump, Comp cam, Kooks, stock bottom end trans and diff. The shake intimidates but drives like easy peasy! Even the wife has no problems on the way to get a manicure!
Blown and built by Ty Sochacki, tuned by Jeremy Formato. Member of the 11 second club.
03-14-2014, 02:32 PM | #8 |
Drives: 2016 2SS Join Date: Nov 2011
I'm at 675 with a LS9 cam and drives like a stock car.
Who Dares...Wins |
03-14-2014, 03:09 PM | #9 |
Drives: Maggie blown LS3 vette Join Date: Aug 2009
I thought that GT9 cam was a "smooth idle" blower cam. It actually shakes a little at idle? How fast is your idle set? Nice set up. My old LS3 was at 650rwhp with a 3.3" front pulley, just a tad bigger blower cam, and a little over 9psi. About 35K blown miles. The only thing done to the motor, other than routine maintenance, was a belt change. Dead nuts reliable.
03-14-2014, 03:18 PM | #10 |
Drives: All things Turbocharged Join Date: Dec 2010
Keep in mind that it's always 15% easier on the engine to make the same whp on a turbo, over a supercharger. Of corse I would recommend you go AGP TT kit. You wouldn't need a cam or long tubes or pulleys or tensioners or anything to hit well over 600whp. Nothing more needed than what comes in the kit. Bolt it on and make 600+whp easy.
03-14-2014, 03:20 PM | #11 |
Or 700, or 800, or whatever you want to set the boost too assuming you have the fuel supply.
Nick
Corvette Z06 -1200ish rwhp |
03-14-2014, 03:39 PM | #12 |
03-14-2014, 03:56 PM | #13 |
I'm 600ish depending on weather and dyno. Bone stock except 9lb Paxton and full exhaust. Sure, fuel system parts have been upgraded but stock LS3 drivetrain other than that. I've got 60lb injectors that are at 97% so I'll be changing them soon.
03-15-2014, 11:12 AM | #14 | |
Thanks Motorhead. The way I understand it is the GT9 can be smooth or rough depending on the tune. All in the ignition timing to get the lope out of it. My idle is set at 750. It is just enough rough.
