11-23-2010, 06:28 PM | #1 |
Drives: 2010 ls camaro cyber grey v6 auto Join Date: May 2010
Best Oil
What is the best oil for the camaro '10 ?
11-23-2010, 06:29 PM | #2 |
Drives: 2010 Camaro SS/RS Join Date: Sep 2008
I use Royal Purple in everything. Hands down in my opinion the best oil out there.
2014 C7 Z51~ M7 custom paint, Mods soon to come, researching at the moment. |
11-23-2010, 08:20 PM | #3 |
Drives: 69Camaro,87IROC,96 SS,Z06&Stingray Join Date: Apr 2010
Any fully synthetic oil that meets the GM spec.
Valvoline Synpower and Castol EDGE are two examples of oils that have now surpassed Mobil 1 on the standard wear test, and meet GM 4718M. |
11-23-2010, 08:26 PM | #4 |
Drives: Blk/Blk 2018 Sierra SLT Join Date: Dec 2006
Mobil 1, doesnt hurt the pocket either
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6 |
11-23-2010, 08:27 PM | #5 |
Drives: 2010 Shelby GT500 Join Date: Jul 2010
royal purple ftw!!
11-24-2010, 06:36 AM | #6 |
BAMF SS
if you can afford it.... redline blows amsoil, royal purple, and mobil 1 out of the water.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
11-24-2010, 09:21 AM | #7 | |
Bye Bye GD
Drives: 2015 AGM SS (Everyday=1 day closer) Join Date: Oct 2010
I use RP right now but if you can prove to me Redline "blows everything else away"... I'll switch.
2010 CGM 2SS RS. Atomic Orange Metallic Stripes. Corsa Cat-Back. MGW Short-Throw. H&R Springs. AAC Halo/Fogs. 20" Havoc Wheels. SRP Pedals. RX Catch Can. Kicker L7 & Amp in ******** Stealth. Garys Custom Fenders. Roto-Fab CAI. Pfadt Trailing Arms. |
11-24-2010, 10:17 AM | #8 | |
BAMF SS
I remember seeing someone send out royal purple, penzoil platinum, castrol syntec, mobil 1, and castrol edge to get some vuoa's, and royal purple came back with the worst viscosity out of all of them. lol. I could search and copy and paste some test results... but you would probably still stick with royal purple. or you could go to the forum and learn what makes a good oil a good oil and what you want in an oil, and how there is no answer to the age old question "What is the best oil" because each person wants something different from an oil. one thing is certain though... royal purple sucks. haha now will you engine blow up because you are running xxxxxx oil in it? highly unlikely. but you asked.
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. Last edited by danhr; 11-24-2010 at 10:35 AM. |
11-24-2010, 10:36 AM | #9 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
Boils down to what was already mentioned...what do YOU want out of an oil? Are you going to change it on a regular basis?
If you're stock, and remain so, then you can't go wrong with Mobil 1, Castrol Syn, etc. I'm not sure which car you have as an LS is a V6 and you show V8 under your avatar. You do NOT have to be limited to the new dexos standards, but going with nearly any affordable and easily accessible "synthetic" oil you should be fine. Go to your favorite auto parts place and see what they sell. At least you know you can get the stuff. For those that claim one brand is better than another...when you're stock, I've never seen any issues due to lubrication properties of the oil, or lack thereof. If you're going to mod for power, only then you probably need to start worrying about oil wedges and oil analysis data, etc.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
11-24-2010, 10:50 AM | #10 |
BAMF SS
jesus used red line oil in his car
so does chuck norris
11-24-2010, 11:05 AM | #11 |
Older Than Dirt
Chuck Norris doesn't use oil. He threatens the metal into keeping distance between itself.
11-24-2010, 11:08 AM | #12 | |
BAMF SS
the paper was then liquidfied, and said substance is called "red line racing oil"
11-24-2010, 11:10 AM | #13 | |
Not easy being Green
Drives: 67 Nova SS Join Date: Nov 2008
17 yr user and fan of redline. With that said I also use Mobil 1 in our new Camaro and Redline products in my Nova. For my DD I use a good standard 10w-40 it has over a 100k w/ most of that in town driving. I bought it new and changed the oil every 3k. It doesn't leak or burn any oil. So as said above it really boils down to what you want to spent and how your going to drive it. M2C
11-24-2010, 11:47 AM | #14 |
Hey Hotbody are you changing the oil yourself or taking it to get done?
Similar Threads | ||||
My V6 oil change experience | convert | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 38 | 04-08-2014 04:15 PM |
best synthetic oil to use | hollywoodjose | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 130 | 01-26-2014 08:51 AM |
GM's OLM & synthetic oils. | duder4thgen | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 03-24-2010 11:37 AM |
