01-12-2014, 10:29 AM | #1 |
Drives: 2011 2SS Synergy Green Join Date: Nov 2011
BIG problem after Maggie install....
I bought a used Maggie from a shop and had them install it with my Apex catch can. The can routing looked funky to me from the start. I picked the car up Thursday.
On my way home I noticed a few puffs of smoke out the tailpipe. I called the shop and they said not to worry about it, it was probably running a little rich. I've driven the car for 2 days but haven't gotten on it yet. This morning I remote started it and it ran for 30 seconds or so then I heard 2 pops and smoke started bellowing out of the tailpipes. It smelled like oil. it isn't smoking as bad at idle but it starts blowing if I let it idle. What. The. ****.
L99 With a Maggie
01-12-2014, 10:30 AM | #2 |
Moderator
While I have no experience with superchargers, that car needs to go to the shop.
Operation Demon//Buy at Invoice//RACECARWEAR RESPECT ALL CARS. LOVE YOUR OWN. warn 145:159 ban |
01-12-2014, 10:34 AM | #3 |
Drives: 2011RedJewel, FI Join Date: Dec 2011
What color was the smoke? If it was black, that's too rich. If the smoke was white to slight blueish that's oil. Smoke color should let you know where to begin figuring it out.
01-12-2014, 10:37 AM | #4 |
Pull the plugs and see. Run a compression test on it and check leak down.
01-12-2014, 10:41 AM | #5 |
B.O.D. 02/16/10
Drives: 2010 SGM Sp. Edition 2017 RS Conver Join Date: Jun 2010
Check the catch can plumbing. There was a guy at the C5Fest III that put his car on the dyno and had a similar reaction. Was simple plumbing reroute. Sure looked terminal when it happened.
01-12-2014, 10:48 AM | #6 |
If you are dumping oil into the intake/blower then it will smoke like crazy. So either you are doing that or a piston/etc let go.
Nick
Corvette Z06 -1200ish rwhp |
01-12-2014, 11:35 AM | #7 |
Drives: 2010 CAMARO SS Join Date: Apr 2010
I had same problem,,,, can was hooked up right,,, but I needed to install a check valve on the line from the blower to the catch can so it couldn't suck the oil in
01-12-2014, 01:37 PM | #8 |
pop off the oil fill cap. if it is puffing smoke heavily from there its not good. otherwise if its not you probably just oil fouled a plug.
01-12-2014, 02:39 PM | #9 |
They had the catch can outlet going to the intake tube near the throttle body
L99 With a Maggie
01-12-2014, 03:28 PM | #10 |
explain your can routing in detail....
01-12-2014, 03:38 PM | #11 |
They had it:
Drivers rear valve cover port to top inlet of catch can Brake booster hose to rear-most maggie nipple Bottom of catch can outlet to intake elbow Passenger side valve cover to front-most Maggie nipple Here is a plug I just pulled from the drivers side
L99 With a Maggie
01-12-2014, 03:47 PM | #12 |
Drives: 2011 2SS Join Date: Jun 2013
I can tell u how my catch can is set up and I have had no issues with it this his how I was told to do it by several I have the driver side vale cover port going to the inlet on my catch can (rx can) then I have the outlet of the catch can going to the rear barb on the Maggie up by the throttle body then I have a breather cap on my oil fill that has a tube going to the cold air intake and the barb on the front passengers side of the valve cover is capped and not used depending on your can it could be differt on the passengers side
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
01-12-2014, 03:49 PM | #13 |
passenger side valve cover goes to tube outlet on cold air intake...
01-12-2014, 03:50 PM | #14 |
[QUOTE=Nutro;7330931]They had it:
Drivers rear valve cover port to top inlet of catch can Brake booster hose to rear-most maggie nipple Bottom of catch can outlet to intake elbow Passenger side valve cover to front-most Maggie nipple[QUOTE] I think you need to re-route your hoses. The one for the brake booster is fine where it is. I'd switch the passenger side valve cover hose to the intake elbow, and switch the catch can outlet to the front nipple on the Maggie. |
