Old 01-15-2014, 02:19 PM   #1
BooSSted
BooSSted's Avatar
Drives: 2017 Z06 / 2012 CTS
Who's cammed ?
Who's running FI w/a cam???
How many miles on your setup?
What oil do you use?
What valve springs were used if known, 3 bolt or single?
Interested in seeing how many FI guys are running cams, seen several topics indicating cammed LS3 aren't making it past 30-50K ODO...
BooSSted is offline   Reply With Quote
Old 01-15-2014, 03:57 PM   #2
elarson5757
Obsessed and Loving It...
Drives: 2013 1LE-SS
I will be so I can't personally provide input but I do know I have several people I know that have 60-80 on their 2010s FI with a cam and no problems.
elarson5757 is offline   Reply With Quote
Old 01-15-2014, 05:35 PM   #3
BlownSS
BlownSS's Avatar
Drives: 2010 Camaro SS/RS
I am cammed with a Magnuson. It is not my daily driver. If you use the search button, you can see a TON of different setups. Alot of what you decide to use will depend on your tuner or shop that is doing the install. Are you planning on doing the work yourself?
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger. 3.4 Pulley. Kooks long tube headers / high flow cats. GHL Full exhaust. ZL1 Fuel Pump/ADM FPCM. MSW Bap. JRE ZL1 Race cam with new springs/pushrods/Trunion Upgrade. FIC 850cc injectors. ZR1 Map sensor. CAI Induction. JRE Tune.
BlownSS is offline   Reply With Quote
Old 01-15-2014, 06:05 PM   #4
Slowhawk
Drives: 1999 Trans Am
Truthfully, it is hard to think of any of my customers with blowers that do not have a cam.
Slowhawk is offline   Reply With Quote
Old 01-15-2014, 06:17 PM   #5
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
22,000
MOBIL 1
TEA .650 in lift
3 bolt
Whipple @ 10lbs 650hp 590tq
Sent from my Samsung Galaxy S4 using Tapatalk
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 01-15-2014, 06:48 PM   #6
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
69K miles here, running Maggie on stock pulley (for now) and cam--9K with the Maggie and cam, over 35K cam-only. 'Been running Mobile 1 since day 1, but about to try the Joe Gibbs oil.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq
fldrummer is offline   Reply With Quote
Old 01-15-2014, 06:58 PM   #7
UNRIVALED SS
UNRIVALED SS's Avatar
Send a message via Yahoo to UNRIVALED SS
I've had an aftermarket cam since I got the car. One in the OEM motor and have one in the built motor now. I ran the AFM lifters in the L99 hard for 20K or more. Never had a problem with the valvetrain . Always ran comp 928 dual springs.
UNRIVALED SS is offline   Reply With Quote
Old 01-16-2014, 09:55 AM   #8
BooSSted
BooSSted's Avatar
I'm getting cammed this Spring and NEP is doing the work. I'm not so much interested in the set ups as I've read over a ton of them. I'm more interested in the success and longevity owners have had with their set ups.
Whats your preference in cams, single or 3 bolt? Valve train hardware company of choice?
SOLD - Maggie Powered 2011 2SS
Procharged Powered 2017 Z06
Old 01-16-2014, 10:05 AM   #9
Neumatic
Drives: 2010 Camaro 2SS M6
3 bolt cam, don't even consider a single bolt cam.
My car has had a cam for about a year now, ~7-8k on it. In the process of installing a magnuson now.
Neumatic is offline   Reply With Quote
Old 01-16-2014, 10:55 AM   #10
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
GPI ss3 vvt cam
BTR dual springs (from plat. kit...nice stuff)
all needed pushrods, locks, ret...BTR/GPI kit
been on since last fall...not a lot of mileage...but a lot of trips down the track and around town...not easy 1k miles by any means.
9psi
mobil1 for now...plan to swap to an oil with zinc in it on next oil change before next track outing
654whp (8.7@119 in 1kft...about a mid 10sec 1320' pass)
-John S.
Old 01-16-2014, 11:34 AM   #11
lpar1969
lpar1969's Avatar
Drives: 2014 1SS NPP 1LE
@ slowhawk: would like to upgrade cam in 2014 Camaro 1LE. What do you recommend?
lpar1969 is offline   Reply With Quote
Old 01-16-2014, 01:25 PM   #12
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
Baby ls9/zr1 cam in mine, Pac beehive 1518 springs, Joe Gibbs oil and 33,000 miles.
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.59@152
2010 Camaro
Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146
94guy is offline   Reply With Quote
Old 01-16-2014, 02:42 PM   #13
Slowhawk
We always use 3 bolt cams from comp. That with C5R chain,brian tooley springs and pushrods to name a few.
Old 01-16-2014, 02:45 PM   #14
Slowhawk
Contact my shop.
