07-04-2016, 06:20 AM | #1 |
Drives: 2015 1LS Red V6 Join Date: Aug 2015
FINALLY! Dyno day is set!
Finally! A dyno day is set, for August 1st at Modified by KC (Dynojet dyno)! Many have you have been wondering when I would get a day setup to test all of the Overkill stuff, against stock, and other bolt ons. Many of you also know that I was able to put down a 316rwhp/247tq (gross) on E85, on a mobile dyno at Street Car Takeover in Kansas City, MO on APril 16th.
My car has the following: Overkill 80mm TB Overkill E85 Kit (will not be tested this go round) Overkill Tune (tuned on 91, and E85) Overkill custom intake (with CAI box) Jacfab Ported Intake Manifold (to Vmax specs) Jacfab Intake Spacer Custom catless downpipes (Thanks DGM!) RPM Stage 2 Diff (3.91 gearing) Magnaflow Res X pipe, straight pipe Elite Catch Can and Clean Side Lots of other stuff.... Some of the things that I will be doing in my 2 hour dyno session, along with the help of a few other members Stock tune vs Overkill tune (with all bolt ons) VMAX TB vs Overkill TB Cold Air Inductions Intake vs Overkill custom intake (With both TB's) Jacfab ported intake vs stock intake Spacer vs no spacer I would love to also do an E85 vs gas, but it takes 2-3 tanks of E85 to level out and have a consistent 70-80% Ethanol content level. And there is really no way to achieve that without completely draining the tank. I will have a spread sheet showing each run, as well as graphs for each run, so we can get some good solid numbers and see what really helps out the most! Is there anything else anyone would like me to dyno/test? I will have it for 2 hours. My goal is NOT to beat my last dyno run, as i just dont see that happening on gas. My goal is to provide information for everyone here to see what truly helps the most, and do some back and forth comparison of products over stock. Thanks
Sponsors:
Overkill Motorsport BCS Auto JacFab Machining APDEG Dream Gear Mobile Audio Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet 5th Gen V6 Performance Facebook Group |
07-04-2016, 06:42 AM | #2 |
Drives: SS Join Date: Dec 2015
Good luck Derek. I am sure were all anxious to see the results.
07-04-2016, 07:28 AM | #3 |
Drives: 2011 Camaro 1SS Join Date: Feb 2016
Do you feel like 10 runs in 2 hours will give accurate results? Do you have cool down options in place? I can only imagine how hot it will be. Perhaps doing all test with E85 may help a bit. At any rate, good luck. I love a good comparison test.
2011 SGM Camaro 1SS/RS A6 - Vengeance Racing built/tuned. 590RWHP/560RWTQ, ADM LSA Conversion, 2.5 Grip-Tec, ZL1 fuel pump, ADM FPCM, FIC1000, VRPD2 Cam and LS3 Conversion with all the internal goodies, American Racing 1 7/8 Headers, no cats, SW Retro Cat Back, ADM Intake, AFCO HX, Varimax Pump, Rotofab Reservoir, B&M Transmission Cooler, VMAX TB, Elite Engineering CC, BMR LCAs, Trailing Arms, Toe Rods, DSS 1000hp axles, ZL1 Bumper and Sideskirts, Night Owl Halos, Matte Black 20" Rohana RC-22 with 20x10-275s/20x11-315s, R1 Concept Premier Drilled/Slotted Rotors, Hawk Ceramic Pads.
07-04-2016, 07:40 AM | #4 |
I think it will be fine, yes. Although not a perfect world, how often is it a perfect world when doing these kinds of things? People want real world numbers. Not the inflated numbers manufacturers come up with in "Best case scenario" and never tell you that it was a 1 time fluke.
E85 is not going to happen this go around, as the majority of users are going to be on gas. I am trying to cater to the masses first, and then the specialty guys. I will do E85 when i can though.
Sponsors:
07-04-2016, 08:07 AM | #5 |
Banned
Drives: 2015 Camaro 1LS M6 Join Date: Jan 2016
That's awesome Derek! You are definitely blazing an uncharted trail for us N/A guys. I'm glad you're not running E-85 this time. Not every station has E-85 and the MPG takes a hit as well.
For the guys who like running E-85, I'm wondering if you could put a small tank of E-85 in the car like guys running meth? That way, if you need the extra power that E-85 provides, then switch over the fuel source and pow you have it. Sort of like a nitrous shot, but way cheaper. Anyway, it's just a theory. I'm really hoping you get close to 390-400 hp at the crank. |
07-04-2016, 09:15 AM | #6 |
Drives: 2013 1LT RS Camaro Join Date: Apr 2016
Wow Derek, sounds like your gonna cover all the bases. I didn't know Overkill had a custom cold air intake. When did that come available?
07-04-2016, 09:16 AM | #7 |
Its not available as of yet. We are still working on some things with it
Sponsors:
07-04-2016, 09:19 AM | #8 |
Good luck, hope you can get it all in only two hours. That's gonna be some quick changes!
07-04-2016, 09:20 AM | #9 |
Ill have a lot of help with me. The swaps dont take that long, especially now that I have done it quite a few times :-)
Sponsors:
07-04-2016, 09:23 AM | #10 |
Drives: 2024Camaro 2SS CE Convertible Join Date: Jul 2013
07-04-2016, 09:32 AM | #11 |
Sponsors:
07-04-2016, 09:37 AM | #12 |
Derek, you always do a great job with lotsa detail in your posts ,can't wait to see the results!
07-04-2016, 11:59 AM | #13 |
May want to change oil before hand and make sure all fluids are 100%. Just a thought
07-04-2016, 11:59 AM | #14 |
Yup! I get an oil change once a month, and check my fluids just as often, if not more, so i should be all set.
Sponsors:
