08-01-2016, 02:35 PM | #71 |
Drives: 2015 1LS Red V6 Join Date: Aug 2015
AWD dynojet. But it's putting out numbers like I'm stock. I guess I just need to remember that each dyno is different and look at the overall between each change. That's it. Positive thinking! Sent from my iPhone using Tapatalk
Sponsors:
Overkill Motorsport BCS Auto JacFab Machining APDEG Dream Gear Mobile Audio Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet 5th Gen V6 Performance Facebook Group |
08-01-2016, 02:36 PM | #72 |
Drives: 2015 Black 2LT RS M6 Join Date: Aug 2015
Hmm maybe it's rigged. It's not reading the front wheels right?
Overkill tune/E85/80mm•CAI cold air intake w/my custom maf tube•Apex air scoop•JacFab ported intake/Extendolater•Vitesse•EE EX2 catch can•Innovate wideband•ARH HFC's•NPP exhaust•11386 xpipe•Brembos/cross drilled/slotted rotors•SS M/C•Pfadt 1.25 springs•1LE struts/sways/strut tower brace•BMR diff bush, trail arms/bush, adj toe links•My custom Tunnel brace•Hurst short throw shifter•JDP stage 1 clutch res•1LE steering wheel, shift boot•ZL1 rear diffuser/splash guards•GM splitter•Z/28 grille/flowtie/spoiler/wheels•GM performance pedals•"Chevrolet" door sills•10" Kicker sub•BigWorm overlays
08-01-2016, 03:49 PM | #73 |
Drives: 2013 1LT RS Camaro Join Date: Apr 2016
Well, let's see what the difference is, like Derek said. That's what is really important. Woulda been nice to see how close to 300hp Derek was going to get.
08-01-2016, 03:53 PM | #74 |
The difference is the key...
08-01-2016, 04:07 PM | #75 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
Don't be to into your numbers.......there are a ton of inflated numbers floating around on here. I thought I would have more rwhp but my tuner said he left some on the table so the car would last 100 thousand miles. What does the v6 come stock in regards to torque? Dyno numbers are all over the place.. ..I dont put as much stock im to them as I used to.
08-01-2016, 04:07 PM | #76 |
Drives: 2015 RS camaro Join Date: May 2016
Cool ...now where are those charts ???
08-01-2016, 04:34 PM | #77 |
I'm driving home. It'll be tonight before I have the write up done. I have not forgot you guys
Sponsors:
08-01-2016, 04:42 PM | #78 | |
08-01-2016, 04:44 PM | #79 |
08-01-2016, 04:46 PM | #80 |
08-01-2016, 04:53 PM | #81 |
I'm just playin', you know that!
08-01-2016, 04:58 PM | #82 |
He needs to find that mobile dyno again
08-01-2016, 05:29 PM | #83 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
if you have the info, please post what your afr was during the test if you did any on e85
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
08-01-2016, 05:33 PM | #84 |
It wasn't a great day. But at the same time I was on e85 last time which is 10-15% higher normally.
So that would make sense with the numbes I got. Sent from my iPhone using Tapatalk
Sponsors:
