Old 06-25-2018, 09:39 PM   #1
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
Jacking up a lowered car
I have bmr "1 lowering springs and a 1le splitter and that only gives about 5 inches of clearance in the front. Its almost impossible to get the jack under the front far enough back to reach the cross member. Is there a safe place to jack it up from the side to pull the front tires off?
StingrayblueSS is offline   Reply With Quote
Old 06-25-2018, 10:08 PM   #2
Hootch
Drives: 2014 1SS/RS
This post has some pics.
https://www.camaro5.com/forums/showt...t=scissor+jack
Hootch is offline   Reply With Quote
Old 06-25-2018, 10:19 PM   #3
Welker2
Ret AF, cancer survivor
Welker2's Avatar
You can either build some low ramps using 4-6 stager cut pieces of 1/2" plywood (i.e. building up from 1/2" to 2"-3" to raise the car high enough to get your jack under the car. Or you can do as many Corvette owners do and buy a low profile jack like this one from Harbor Freight:
https://www.harborfreight.com/3-ton-...ump-61282.html
Old 06-25-2018, 11:55 PM   #4
Terryfied
Terryfied's Avatar
Drives: 2010 2SS L99
I just back up onto a couple of 2x6. Makes for enough clearance to roll the jack under
Terryfied is offline   Reply With Quote
Old 06-26-2018, 12:53 AM   #5
StingrayblueSS
Thanks for the tips I'll try the 2x6s that might be enough.
Old 06-26-2018, 06:31 AM   #6
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
This is your best option. I'm lowered a little more than an inch, along with 285/35 in front, which drops it another 1/2", then have Razzi side skirts which it looks like its about 3" from the ground.
Along with these guys, I have a set of Race Ramps that I can put under the back tires (backing up onto them). This gives me enough clearance to get the back jacked up, then getting the front is easy.
Old 06-26-2018, 07:20 AM   #7
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
What I've done, as well as some of my buddies who are lowered, is we will put a piece of wood under the car and drive onto it and then jack the car up. Seems to work out alright so far.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 06-26-2018, 08:27 AM   #8
matar123
matar123's Avatar
Drives: 2012 Camaro 2SS Ls3 Cammed/Blown
hrpiii your set up looks crazy what splitter is that?
matar123 is offline   Reply With Quote
Old 06-26-2018, 08:39 AM   #9
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Thanks!! The splitter is by RPI Designs, from here on the forum
Old 06-26-2018, 10:46 AM   #10
go_go_gadget88
go_go_gadget88's Avatar
Drives: 2010 Camaro 2SS/RS ABM 6M
I have this exact jack. It works fine for stock ride height/tires and the factory ground effects. However, there is only ~1/4" of clearance under the front. I plan to do a 1" drop this winter, and I don't think this jack will work for the front end anymore. Definitely gonna have to make some wooden mini-ramps for it. Not sure how that is going to work yet
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
go_go_gadget88 is offline   Reply With Quote
Old 06-26-2018, 06:08 PM   #11
Soybeanrice
Soybeanrice's Avatar
Drives: 2014 2SS/RS
rubber pad on low profile jack, jack on the scissor jack point behind the front tire. raise car enough to put a jackstand underneath subframe and then move jack under crossmember. never bought wood.
Soybeanrice is offline   Reply With Quote
Old 06-26-2018, 06:17 PM   #12
EMB135Driver
Jedi Master
EMB135Driver's Avatar
Drives: Boeing 757/767+2010 IBM 2SS
That Harbor Freight jack works well, but don’t pay $98 for it....frequently on sale for 79.99.....think I got mine for 73.99
EMB135Driver is offline   Reply With Quote
Old 06-26-2018, 09:07 PM   #13
StingrayblueSS
Now that I know scissors jack points I'll probably do this .
Old 06-26-2018, 10:46 PM   #14
Terryfied
Terryfied's Avatar
Go for it buddy, that'll save ya a bunch of time.
