05-26-2021, 10:35 AM | #29 |
Drives: 19 ZLE A10,17 SS 1LE, 16 C7R,CT5V Join Date: Feb 2017
Need them 850whp cats bud. Or tear em out.
05-26-2021, 01:38 PM | #30 |
Drives: 2019 ZL1 Join Date: Mar 2019
They are out. Spoke to Alex at CSP. They should have the new gesi gen 2 1700hp rated cats soon. These will bolt to their csp headers and just need to be welded to my front pipes. I’n the meantime I’m Thinking about getting the borla 60608 resonator. I see that it’s 2.75” only for the ss, but I’m Wondering if I’m can just expand the ends a bit so it slips over my front/rear pipes. I’d rather not weld anything just in case I want to remove it.
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
05-26-2021, 01:58 PM | #31 |
Drives: 2017 ZL1 Join Date: Apr 2020
I have the ARH high flow cats. I'm at around 750 at the crank. They have 17000 miles on them. Anyone have experience with them ?
2017 ZL1 M6 Silver Ice Metallic
05-26-2021, 02:10 PM | #32 | |
Honestly, for the price that an endoscope costs it’s worth the security. Stuck it down an o2 bank/bung for quick visual. Once they start to go, they go quick as the airflow is reduced more and more.
05-26-2021, 05:11 PM | #33 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
I'm at around 750whp on e60. My Kooks std high flow cats are still holding up after around 12k miles. I've heard the Kooks high flows hold up as well as their Green cats.
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels & brakes/GForce DS and axles/ZLE Cradle Bushings/FE4 ARB front & rear/SEMA Grill/Rotofab dry/95mm TB/Magnuson 2300/Full LT4 fuel system/JMS boost-a-pump/E85 Sensor/Ported CID heads from LME/Cammotion PD cam/Thompson Motorsports forged shortblock/catted Kooks 1 7/8 headers /JRE remote tuned |
05-26-2021, 05:46 PM | #34 | |
When I read this it tells me you don’t spend enough time at wot. No disrespect. But if your driving it like you stole it for 12k those cats shouldn’t last. Mine didn’t make it 20 track miles. Sent from my iPhone using Tapatalk |
05-26-2021, 07:06 PM | #35 | |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
I look for before taking anyone’s advice here for gospel. And don’t get me wrong, I’m not saying he doesn’t have valid info to add, just that when discussing causes and effects on ZL1s with LT4 I always make sure I’m getting info to that spec.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
05-26-2021, 08:12 PM | #36 | |
This.. Boosted is a big killer of cats. Another reason why kooks/gesi don't warranty the high flows on boosted applications is because they are even worse then the greens. The green cats are indeed a good product, but they are rated at 425hp per bank, that's the problem. I am hoping these new ones by gesi rated at 850hp (per bank) hold up better. Like alex at CSP said, they have to be making better ones for a reason because these Gen 1's just cant handle the power.
05-26-2021, 10:10 PM | #37 | |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
05-26-2021, 11:09 PM | #38 | |
But i love to eat... HAHAHA
05-27-2021, 08:49 AM | #39 | |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA Last edited by KingLT1; 05-27-2021 at 09:01 AM. |
05-27-2021, 09:20 AM | #40 |
I don't run it like I stole it except on track days. I also never track on straight 93, I always run at least e55 or so. On the track, I definitely do not go easy on it. I run in the advanced group unless it's my first time at a particular track and am always one of tthe fastest cars. I have out paced McClaren 720s', ZLEs, Z06s and various Porches that should have been faster. I am very surprised that my cats haven't melted, and while it's possible that I'm on borrowed time, I believe the combination of e60 and Ted J's turning are keeping those cars alive.
Baby Blue
05-27-2021, 09:22 AM | #41 |
I am sure the Ethanol helps being it lowers cylinder temps which will lower EGT's.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
05-27-2021, 11:02 AM | #42 | |
Baby Blue
