#Camaro6
Old 03-25-2024, 08:45 AM   #1
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - Modified All Bolt On's
ZL1 piece of foam under supercharger...
Now that I have the supercharger off and at Kong getting ported/polished. I can't help be keep staring at this big piece of foam that sits on top of the valley area/under the supercharger. With this being the last planned time I'll have the supercharger off my car:
1) Is the piece of foam needed or server any real function such as sound dampening, or heat shielding?
2) Can it be removed and nothing go in it's place?
3) Do they make a (not really a valley cover) but something that can go in place of the foam for the 2023 ZL1?
3a) My tune has AFM is disabled.
Just looking for opinions and options since the blower is off probably for the last time!
Thanks
2023 ZL1 A10 - CSP 2" Long Tube Headers by Stainless Works | Gesi G-Sport High Flow CATs | Stainless Works Legend NPP Axle Back | Roto-Fab Big Gulp | Kong NM103mm | Kong X-Port/Polish w/Griptech 2.3" Upper | Granatelli Malevolent Coil Packs | Granatelli 0 Ohm Plug Wires | Katech Valve Covers w/Coil Relocation | FI Interchillers Blower Spacer Plates | Mighty Mouse Mild | JMS Flex Fuel Booster | DSX Flex Fuel Kit | DSX Billet Lid | DMS 2gal Fender Tank | NT555R2's 305/285 | AEM w/b AFR | Banks iDash Data Monster | HPTuners MPVi3 Module and Licenses (ECU & CCM) | Remote Tuned by Ted at JRE
2023_ZL1-AUTO is offline   Reply With Quote
Old 03-25-2024, 11:20 AM   #2
Owl3
Drives: 24 Sliverado 1500 ZR2, 2017 ZL1
Looks like a thermal blanket....
Finally on the way to 1K.....
Owl3 is offline   Reply With Quote
Old 03-25-2024, 12:23 PM   #3
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I’d guess noise suppression. The DI system is much noisier than port injection and most manufacturers take efforts to tame that noise down.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
Joshinator99 is offline   Reply With Quote
Old 03-25-2024, 12:54 PM   #4
Katech_Mike
Drives: 2015 Camaro ZL1
The purpose of the foam is to dampen the noise of the injectors and HPFP.
You can remove it if you want.
All aftermarket PD style superchargers require removal of the foam.
Katech_Mike is offline   Reply With Quote
Old 03-25-2024, 01:27 PM   #5
2023_ZL1-AUTO
THANKS MIKE!
Old 03-25-2024, 01:52 PM   #6
Joshinator99
Copy cat…!
Just playing my friend! Thanks for confirming.
Old 03-25-2024, 02:11 PM   #7
2023_ZL1-AUTO
Copy cat…!
Thanks Josh... When I checked I saw Mike's post but not yours's weird I was using my Cell phone to view. Thanks!!!
Old 03-25-2024, 02:20 PM   #8
Joshinator99
No worries my friend. I’d take Katech Mike’s advice first too haha!
Old 03-26-2024, 07:13 AM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I used a thermal product under the 2650 before installing it. Surprisingly - the DI, to me, isn't more noticeable, but I'm also the guy that would accept a little more noise (if the only after effect would be noise) for better cooling or bigger blower, etc.
'20 ZL1 Black "Fury"
Old 03-26-2024, 07:27 AM   #10
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Seems like it would also provide a thermal barrier...?
I wonder if the small air gap would hurt or help heat soak?
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC
Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank
ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE
BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi
SOCAL.M6.ZLE is offline   Reply With Quote
Old 03-26-2024, 07:42 AM   #11
Joshinator99
Agreed, @Radz28. I used a piece of adhesive backed reflective insulation on the bottom of my old 2.9 and will likely do it again next time I take the 3.0 off for whatever reason. It was thin, had a reflective finish, and left an air gap.
@Socal, a small air gap helps. Air is actually not a great transmitter of heat so a small gap will help. A large portion of the heat transfer is from the direct metal-to-metal contact at the blower-to-head flanges, unfortunately. Is what it is.
Old 03-26-2024, 07:47 AM   #12
2023_ZL1-AUTO
Thanks guys! So, I think my plan will be to remove the foam and place a thermal blanket where the foam sits now on top of the valley. I'll make sure to cut the thermal blanket to the exact footprint of the bottom of the foam. Then, add a thermal blanket to the bottom of the supercharger as well. I'm also adding the the Forced Induction Interchillers Supercharger space plates. So this will give a bit more of a gap in my install. One thing that would drive me crazy after doing this. Is if the injectors have a noticeable sounds such as a tick, a manifold/header leak or the sound of noise lifters or valves. I hope I don't do something I end up regretting !
Old 03-26-2024, 08:25 AM   #13
Camfab
Drives: ‘23 ZL1-1LE
Thanks
I’m not going to lie, I did laugh, when I read this was the last planned time you’re taking the blower off.
Camfab is offline   Reply With Quote
Old 03-26-2024, 09:52 AM   #14
2023_ZL1-AUTO
Haha... That's funny... Because after I re-read my own post, I laughed at that statement as well!!! But I guess planned, doesn't mean never !!!!
