Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 05-19-2014, 04:06 PM   #1
GSTRYDR
Ghost Ryder Z
Drives: 2018 Nightfall Gray ZL1
Garage Floor Epoxy
I am looking into epoxy floor coverings for my newly build shop (24x24) I have read lots of info in the web and have come to 3 main choices that all are similarly priced. Armor Garage, Armorpoxy - Armorclad, and Versatile building products - Roll on Rock. Does anyone have any experience with any of these? The Armorclad seems to be the most reasonably priced of the three offering a 600 square foot kit where the others are only 500 and 750. I need enough to do ~576 square feet. My reason for choosing these three over the big box store epoxy is these are all Solids epoxys that are solvent based. These two factors seem to always be rated higher than water based epoxy. Thanks
GSTRYDR is offline   Reply With Quote
Old 05-19-2014, 04:16 PM   #2
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
Garage Floor Epoxy
Rustoleum professional topped with their clearcoat system
Bottom pic left is after winter before cleaning right side is cleaned
Ryan
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
Old 05-19-2014, 04:36 PM   #3
GSTRYDR
Ghost Ryder Z
Ryan
Looks great, but do you park directly on the floor or park with your tires on mats? I know that is an option and the Rustoleum Pro is much cheaper than the systems I am looking at with plenty of cash left over to purchase the mats! I just don't know if that is what I want. Not knocking it, just being my picky self. Thanks for the input.
Old 05-19-2014, 04:59 PM   #4
Ryanbabz71
Ryanbabz71's Avatar
Yes I park with the tires on the mats. I had issues with the regular rustoleum kit and want to make sure this lasts , probably overkill
Ryan
Ryan
Old 05-19-2014, 06:25 PM   #5
DARK AGE 53
DARK AGE 53's Avatar
Drives: 2010 SS
If you haven't checked out this forum out yet you might want to, http://www.garagejournal.com/forum/f...sprune=-1&f=20 .
POW/MIA - YOU ARE LOST BUT NOT FORGOTTEN IN SOUTHEAST ASIA
DARK AGE 53 is offline   Reply With Quote
Old 05-21-2014, 06:30 PM   #6
GSTRYDR
Ghost Ryder Z
Thanks for the idea. I joint the forum and there is tons of info about flooring on there. I also found that you can get some great discounts by being a member too just like on here!
Old 05-18-2015, 10:23 PM   #7
Ronv
Drives: stylish
I’m not aware with technical terms involved in the installation of floor coating. But I do have an experience as I have installed epoxy resin floor coating for my newly built house by hiring the floor contractors from Mississauga. It’s really worth it. I recommend you the same as well. If have any queries then you can follow this link ( http://www.epoxytoronto.com/products...-overlayments/ )
Ronv is offline   Reply With Quote
Old 05-22-2015, 08:02 PM   #8
JohnnyC
PURBRED
JohnnyC's Avatar
Drives: 2014 Camaro ZL1, 2007 Gmc Duramax
I used the rustoleum last summer and park my car and diesel on it all the time.
Holding up good and pressure washes and cleans easy.
JohnnyC is offline   Reply With Quote
Old 05-24-2015, 12:55 PM   #9
nitto85
Caffeine Injected
Drives: 13 Ram - 05 Widebody 1050rwhp Vette
A guy at my work did this to his garage, and he said his hot tires peeled the coatings off.
Now I don't know what brand he used, etc. But he recommended that anyone get someone who can do a commercial grade application.
I'm not sure what the price difference would be, but he is smart and fairly wealthy. I'd imagine that his initial application was done right.
nitto85 is offline   Reply With Quote
Old 05-24-2015, 09:46 PM   #10
pony
pony's Avatar
Drives: 2011 2SS Convert; Color RJT
You are right in checking around, and i too would NOT consider the box store epoxy coatings if you want it to last. I went with the 100 solids epoxy products from the below link. They have held up perfectly over the past 6 years; hot tires and all, and still look brand new. Definitely use the 2 part polyurethane gloss/semi-gloss topcoat as well. Custom color chips available as well as videos of install tips.
http://www.originalcolorchips.com/store/
pony is offline   Reply With Quote
Old 05-24-2015, 09:52 PM   #11
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
Blanket truth about Epoxy, if it's not catalyzed (ie. 2 parts Paint and Hardener) it's not really an Epoxy...
Sent from my QTAQZ3 using Tapatalk
Firefighter is offline   Reply With Quote
Old 05-24-2015, 09:56 PM   #12
Carmikaze
HTCC Membership Director
Carmikaze's Avatar
Drives: 2013 RS Camaro
I would go with race deck flooring
Carmikaze is offline   Reply With Quote
Old 05-25-2015, 01:23 PM   #13
moiy1983
moiy1983's Avatar
Drives: 2010 camaro ss/rs
I used Sherwin Williams Armor Seal 1000 2 Part epoxy. After coating with epoxy I coat with Armor seal clear epoxy. It makes a huge difference when it comes to stains and clean up. Im a paint contractor and been love this product. Ive used this in residential and commercial jobs and they love it. Its not cheap but a wise investment.
2010 SS @gt_klr Built by Jrod Tuned by Matt Sorian
LSX 434 by HKE Dragon Slayer, Callies ultra rods, Wiseco Coated Pistons, Mast 285cc LS7 Heads
ProCharger F1-X
Nitrous Outlet Direct Port
Fore Innovations Triple Pump on E85
Alky Control Meth Injection
ProEFI ECU
Stainless Works 2" Headers with Corsa 3" Exhaust
RPM 4l80e with Jakes Transbrake
BMR Everything with 15" Conversion
Zl1 Front Brakes & Carlyle Racing Rear Brake Kit
Weld Wheels
moiy1983 is offline   Reply With Quote
Old 05-25-2015, 10:17 PM   #14
cajun1le
The Mechanic
cajun1le's Avatar
Drives: a sports car
How well does this coating hold up to UV/sun? When I was in the process of renovating the garage, I kinda went on the cheep side with the with the Rustoleum epoxyshield kit. If there is ever an excuse to repair the floor, I will definitely have to keep this product in mind.
cajun1le is offline   Reply With Quote
