12-11-2013, 10:14 AM | #1 | |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
"Swirled" door panels?
Has anyone done a paint swirl treatment to their interior door panels?
Something like this (start at 4:25):
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
12-11-2013, 10:33 AM | #2 |
knows 2 facts about ducks
Isn't that hydo-dipping?
12-11-2013, 10:42 AM | #3 |
2010 2SS/RS M6
Yep.
Basically a bucket of water/borax, then float some thinned out oil paint across the surface, and then you slowly dip the object into the bucket. The paint adheres to the object as it's dipped. I would probably put a clear-coat over the top to protect it.
