02-10-2015, 07:42 PM | #1 |
Chevy For Life!
Drives: 1SS 2010 Rally Yellow Join Date: Jul 2009
Preventing Dry Start
Hi all. Each winter I store the car and it will sit. My fear is having a dry start. The goal is to crank the motor without starting it, circulating the oil. So far, two ideas were mentioned: 1) Installing a oil accumulator or 2) Pulling the Fuel Injection fuses (Mini Fuses 9 and 10). Option 2 is definitely cheaper and easier. Does anyone foresee any repercussions pulling the fuses? Thanks
02-12-2015, 06:57 AM | #2 |
Drives: 2010 Camaro SS, 2018 Colorado Join Date: Nov 2009
Gas pedal to the floor, turn key. Car will crank without starting, or so I've read. Haven't tried it.
02-12-2015, 07:18 AM | #3 |
Drives: 2011 2SS/RS LS3 Join Date: Jan 2015
02-12-2015, 12:18 PM | #4 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
I just fire mine up a few times during the winter. It'll start fine and is still lubed if it only sat for a couple months.
Keep in mind, gas is also pretty slippery. If cranking it with no injector pulse, the cyl walls are probably less protected than with fuel pulsing. I would just fire it up. Take a long drive, half hour or more, then change the oil. Over winter, gets a lot of condensation in there, good to get the winter oil out after a long drive has cooked out a lot of the condensation. |
02-12-2015, 07:10 PM | #5 |
Drives: 2014 Red Camaro 1SS 1LE Join Date: Aug 2014
I'd like to know if this works. If it doesn't, and the car fires up, it is going to instantly rev up with little lubrication . . . thus having the opposite effect of what the OP was looking for.
02-12-2015, 07:17 PM | #6 |
Drives: 2010 SS RS Join Date: Jan 2015
My 2ss ls3 the pedal to the floor works. It'll turn over for a few seconds then stop.
02-13-2015, 11:13 AM | #7 | |
Cars sit all the time for months at a time without starting. They still have oil coating the stuff from when it was last ran. It doesn't evap quickly like gas. A real dry start is on a fresh build. Oil and assembly lube on all the imporant stuff. Pre-prime the oil system with either a pressurized preluber, or on the old school motors spin the oil pump with a drill. Then fire the motor. On a modern car that has just sat for a few months, I'd just turn the key and drive it normally. It'll be fine. Sometimes you'll hear a few rattles in that first minute. And that is just lifters that have bled down over time from valve spring pressure. Start it once a month and run it for a half hour during the winter and you won't even hear any lifters that have bled down. That and some stabil in the tank is all that is really needed. If something sat for 10 years, I'd be lubing the cylinders and pressurizing some new oil in there and a complete fuel system flush. A couple months, I'd just hit the key. |
02-14-2015, 07:57 PM | #8 |
Chevy For Life!
Thanks for the replies. I'm happy to hear that the flood clear mode works for an LS3. I'll see if it works for the L99 (my motor). I called the dealership and they didn't think that our particular car had such a mode. A suggestion was made to pull the fuel pump fuse instead of the injector fuse. Crank the motor over a few seconds and put the fuse back in. Maybe I'm a little cautious but those first few seconds after each winter really makes me shiver when the car goes "knock,knock" then smooths out.
02-14-2015, 08:22 PM | #9 |
Drives: Camaro Justice Join Date: Jun 2007
Accusump
02-14-2015, 11:06 PM | #10 | |
I am not "Fast & Furious"
Drives: 2010 Camaro LSX454 1LE Join Date: Nov 2008
The day I take a bend too fast
Judgement that could be my last I'll be wiped right off the slate Don't wait up 'cause I'll be late, I'll be late |
02-16-2015, 12:17 PM | #11 |
Drives: 14 Camaro 1LE,328i, and some Hondas Join Date: May 2014
Accusump is your best bet for a wet sump system. With a dry sump, you could turn the oil pump by drill to get oil to the bearings. Flood clear mode still turns the motor over dry. It just has no spark.
14' Camaro 1LE - Now self-tuned
FRH ported heads, Cam Motion LL solid roller, Jesel rockers, Morel lifters, Kooks headers, Corsa exhaust, ADM intake, Stock compression/bore/stroke 551whp 504wtq |
02-16-2015, 01:56 PM | #12 |
The risk of the drill prime is forgetting to replace the cog belt Not that that has ever happened to a racecar
02-16-2015, 02:32 PM | #13 |
Lol ouch. Painful to think about. Easy to happen though in the mix of things.
02-16-2015, 02:44 PM | #14 |
Drives: Camaro Join Date: Aug 2014
Just start the car.
Using just the starter will not move enough oil to get it anywhere in the engine. This way will cause more wear than just starting the car. |
