09-02-2014, 09:47 PM | #1 |
Drives: 2010 CGM Chevrolet Camaro LS Join Date: Feb 2014
Suspension Upgrades for my Camaro
Just received the last of my suspension upgrades today:
Prothane Subframe Bushing Inserts Prothane Steering Rack Bushing Prothane Front Radius Rod Inserts Front Camber Bolts Spohn Performance Toe Rod Ends I already have installed: FE4 Front & Rear Struts, Hotchkis Sway Bars & Springs, Whiteline Sway Bar Links, Spohn Performance Front Chassis Brace, Spohn Performance Tunnel Driveshaft Brace, and Spohn Performance Trailing Arms. My question is: "Does anybody have a similar setup, and how is the performance of your Camaro after this setup with an aggressive alignment setup?
2010 Chevrolet Camaro CGM LS - Performance Mods: "Everything I can get bolt-on wise to make it run good!"
Exterior Mods: "Everything I can get to make it look good!" Interior Mods: "Everything I can get to make it look good!" |
09-02-2014, 11:07 PM | #2 |
Drives: 2010 Camaro SS Join Date: Feb 2012
Where did you get the subframe bushings?
09-02-2014, 11:18 PM | #3 |
I got the subframe bushing inserts from Ebay. They came in the color red, and I painted them black.
http://www.ebay.com/itm/181150340003...84.m1497.l2649
09-03-2014, 06:38 PM | #4 | |
We stock them as well; available in Red or Black. Best regards, Tyler 888-308-6007 |
09-04-2014, 12:01 AM | #5 |
KaBoom1701
DP,
I think you and I are on the same path. lol I just did a 1LE suspension upgrade show here: http://www.camaro5.com/forums/showthread.php?t=373667 You may be further along with your bushing upgrades.
Mods:
09-04-2014, 08:59 AM | #6 |
Dyno Show Queen LOL
Drives: 16 SS & 17 ZL1 Both Yellow Join Date: Jan 2014
Was this done this way because those were the best prices for the items you were looking for? Instead of staying with all one maker... looks like you got a assortment of companies.. I was thinking the same. I mean 500 sway bars vs. 300 dollar sway bars!
09-04-2014, 09:49 PM | #7 |
My Hotchkis Sport Sway Bar set cost me $300 from Ebay.
09-04-2014, 09:52 PM | #8 | |
