01-26-2015, 10:12 PM | #1 |
Drives: 2010 2SS/RS M6 IOM, 1995 Blown Z28 Join Date: May 2009
Air conditioning blows cold on passenger side but not drivers side?
Center vent passenger side blows cold air but the center vent drivers side blows outside temp (80 degrees today)? Is there a "air routing control" for side to side action?
2010 2SS RS M6 Inferno Orange Metallic
1995 Z28 - blown, intercooled and nitrous injected - Sold 1968 Camaro - Sold 2019 Corvette Grand Sport |
01-27-2015, 01:32 AM | #2 |
*new car smell*
Drives: 2007 Ford Mustang 'Natasha' Join Date: Jan 2007
could be low on coolant when I had to replace a condenser on my Monte and recharged the system I noticed that I only had AC on one half of the dash. I went back and had more added as I had ZERO in system (it leaked out of the broken condenser) they added more and I had 100% come out of the vents.
"May the forces of evil become confused on the way to your house."
George Carlin |
01-28-2015, 02:17 PM | #3 |
Thank you for the reply. I believe an minimum coolant pressure is required to activate the system.I
03-24-2015, 09:17 PM | #4 | |
Mine just started doing the same thing after sitting all winter. I suspect low on freon since I did have the motor out. What was the verdict on yours?
2013 ZL1 IOM, ADM ZL-750 700.53HP/ 681.83TQ
03-25-2015, 05:15 AM | #5 |
Drives: 1LE Join Date: Feb 2013
I had a Toyota that would only blow cold out one side -- it was indeed low freon.
03-27-2015, 03:45 PM | #6 |
It was indeed low on freon, problem solved.....unless there's a leak, then it's just begun...
