04-20-2015, 02:47 PM | #1 |
Drives: 2019 Chevy Equinox Premier AWD Join Date: Mar 2011
Racing Brake Motorsports compounds - On Track
Has anyone with or without the RB 2-piece rotors used the RB XT track compound pads? I'm pretty much a fan of the Hawk products but I'm thinking of using their compound to go with the RB rotors and I am curious how well they perform on track. I'm not really concerned with road use, dust, or noise.
If you did so, which ones did you use? XT960, 970, or XR970? Initial Bite? Fade resistance lap-after-lap? pad life? rotor wear? Very interested if you've tried and compared both the Hawk DTC-30+ or the new Hawk street/race pads and any of the XT compounds and in particular with the RB rotors on a road course.
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43) |
04-20-2015, 05:52 PM | #2 |
From this thread it looks like Cobalt Friction pads might be the way to go:
http://www.camaro5.com/forums/showth...review&page=17 But I'm curious if any others have used any other combos with success on the track with these rotors??
(1 of 43) |
04-20-2015, 09:20 PM | #3 |
Drives: Camaro Justice Join Date: Jun 2007
If you drive fast and hard, CF pads are great. XR1 front and XR3 rear
04-21-2015, 02:32 AM | #4 |
Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
The Cobalt Friction pads are awesome on the track, but do not use them on the street. Even driving out to the track is not recommended.
I ran the XR1 and XR3 setup that Pete suggested, but driving to the track ate my rotors. These are extremely aggressive pads that need a lot of heat to work. When they are cold, the pads are much harder than the rotors and will chew through them. I'm trying the Performance Friction pads this year. My friends in the Chump Car series uses these with great results. Low rotor wear and good pad life. |
04-21-2015, 12:29 PM | #5 |
We've been using the Hawk DTC 60s on all 4 corners with great results. They have a good, wide temperature range.
Best regards, Tyler 888-308-6007 |
04-22-2015, 09:51 AM | #6 |
How did you get past the ABS activating in the rears? When I tried the street/race pads (essentially DTC-30s) this happened.
(1 of 43) |
04-22-2015, 10:11 AM | #7 |
Drives: 14 1LE Join Date: Mar 2013
What's your brake setup? 6/4 or 4/4 piston?
LMS Engineering
04-23-2015, 09:27 AM | #8 |
stock calipers and steel lines.
(1 of 43) |
04-23-2015, 09:42 AM | #9 |
What are your alignment specs?
04-23-2015, 10:49 AM | #10 |
The 4/4 piston set up is closer in size and stopping power front to rear. A split in compounds might be needed to keep the rear from being too agressive. With the 6/4 setup that Tyler runs, it offers a different bias that allows for running the same compound front and rear without the rear becoming too agressive.
LMS Engineering
Thread Tools | |
