Old 04-03-2014, 08:07 PM   #1
ss/rs/378
ss/rs/378's Avatar
Drives: 2012 ZL1 Camaro Victory Red
Rear Gear Lube
looking to change rear end gear lube bought the car with 8000 miles on her oil was changed but don't think rear end fluid was what does everyone recommend would like to get this done before my long drive to Camarofest at the end of the month?
2.55 UPPER PULLEY,100MM IDLER PULLEY,160 STAT,PORTED TB,PORTED SNOUT,MSD PLUG WIRES,NKG PLUGS,KENNE BELL EXTERNAL FUEL PUMP,2"KOOKS HEADERS,HIGH FLOW CATS,3"CORSA 60LB DEKA INJECTORS TUNED BY FROST 580RWHP,571RWTQ.
ss/rs/378 is offline   Reply With Quote
Old 04-03-2014, 08:20 PM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
get the GM stuff. Lots of noise issues with non GM fluid. GM fluid is expensive but has the correct additive package for our sensitive rear. 75W-90 Limited Slip (GM Part No. 88862624, in Canada 88862625).
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 04-03-2014, 08:51 PM   #3
Blown355
Blown355's Avatar
Drives: 2017 ZL1 A10
+1
I tried Royal Purple, but it caused the rearend to moan during low speed turns. Went back to the GM fluid and the moaning stopped.
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
Old 04-04-2014, 05:24 AM   #4
ss/rs/378
ss/rs/378's Avatar
Sounds good to me go with what came in the car from the factory thanks guys!!
Old 04-04-2014, 06:44 AM   #5
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
I just did mine. Got the lube from gmpartsdirect.com. Takes 2.1 qts so I bought 3@$13.70+$9.97 ship. It's over twice that at the dealer, if they even stock it, which mine didn't.
Old 04-04-2014, 07:59 AM   #6
Tyler H
XLR8TNG
Drives: 2013 Camaro ZL1
I use Pennzoil 75w90 Synthetic GL5 with a bottle of GM limited slip additive.That is what was recommended to me by the technical service rep I spoke to at Shell. Seems to work just fine. The GM fluid for the ZL1 just has the limited slip additive mixed in with the gear oil already.
Tyler H is offline   Reply With Quote
Old 04-04-2014, 09:45 AM   #7
G Money
G Money's Avatar
Drives: 2013 ZL1, 2016 Denali HD
+ 2
LSX 427, Twin Precision Turbo's, 64/66. Nitrous Outlet System. Pro EFI Engine Management Systems. Vengeance Racing Built......
G Money is offline   Reply With Quote
Old 04-04-2014, 09:55 AM   #8
hognutz
hognutz's Avatar
Drives: 2013 ZL1
you can really use any approved fluid as long as the friction modifier content is correct I would think.
If you buy a cheaper more widely sold brand just have some some GM friction modifer on hand.
if you get chatter or moan you add some modifer and drive the car in a figure 8 pattern. you just repeat this till it is noise free.
I just used the factory fluid though as if you buy it fromt he right place it is not much more.
shopping for 2017+1le or zl1
2009 CTS-V -sold
2015 Hellcat-sold
2013 ZL1 -sold
2007 Z06- sold
2014 Chrysler 300
2011 Duramax 8" lift, deleted tuned
hognutz is offline   Reply With Quote
Old 04-04-2014, 10:04 AM   #9
nxttruck2002
Drives: Camaro
Anyone have thoughts on Red Line 75W90 GL-5 Gear Oil?
nxttruck2002 is offline   Reply With Quote
Old 04-04-2014, 01:26 PM   #10
ZED SLED
ZED SLED's Avatar
Just buy the GM stuff. They're going to need the money to pay off the ignition switch lawsuits so they can concentrate on continuing to build Camaros
Old 04-04-2014, 05:20 PM   #11
ss/rs/378
ss/rs/378's Avatar
Hey thanks everyone I think I will go with the limited slip lube from GM!
Old 04-05-2014, 11:40 PM   #12
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
I don't recommend Royal Purple, lots of the guys on the 1LE section have had issues with it, including me. Ive heard good things about redline.
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 04-05-2014, 11:48 PM   #13
Todd in Vancouver
Todd in Vancouver's Avatar
Drives: 2014 ZL1
I used the GM LS fluid in mine and have had no issues. Just easier to stick with the GM recommended stuff and avoid the hassles.
Todd in Vancouver
'14 ZL1 Camaro
'67 Camaro SS Pro-tour in process
How hard can it be...
Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession
Todd in Vancouver is offline   Reply With Quote
Old 04-06-2014, 12:03 AM   #14
White_SS/RS
Drives: 14 1LE
He has a point! GM stuff is proven to work, however for sever duty there may be better choices. IMO
LMS Engineering
