01-11-2012, 05:24 AM | #1 |
5:30 somewhere
Drives: 2015 Mustang GT Join Date: Nov 2011
Camaro got shocked.
My camaro had a power line fall on it. The line laid on it for about 30 minutes hot before they got it off. Will this damage the electronics on the car? Car ran fine on the way home but what about down the road? My paint was fine but it scratch up my 370z pretty good. Both cars are 2012. Just wondering if the electronics are damaged?
01-11-2012, 06:27 AM | #2 |
Highly doubt it, car was not grounded with rubber tires.
01-11-2012, 06:41 AM | #3 |
Drives: 2019 Camaro 2SS 1LE Join Date: Aug 2011
I doubt it too, but if it will make you feel better, perhaps your dealer can run a diagnostic to be sure.
01-11-2012, 08:08 AM | #4 |
Drives: 2012 IBM Camaro 1LT RS Join Date: Aug 2011
You have a 2012 Camaro AND 370z? :O I want your job.
-Xbox Live: MattCaptainH00K (0s are zeros)-
Team LFX Thread Link: http://www.camaro5.com/forums/showthread.php?t=187109 Team LFX Group: http://www.camaro5.com/forums/group.php?groupid=306 |
01-11-2012, 08:15 AM | #5 |
Cars can be hit by direct shots of lightning and not be affected. As others stated, no grounding, no problem. Had either of the cars been grounded, you would have watched them arc and burn to the ground.
Cars and women are both going to give you problems...but you can pay somebody else to fix your car!
01-11-2012, 09:24 AM | #6 |
Drives: Granite Crystal Challenger SRT Join Date: Jan 2010
I would say that this was not a high voltage line,more like a house service 240 volts or less.A high voltage line would have burned his car to a crisp even with rubber tires isolating the car from ground the metal alone would cause an arc.
01-11-2012, 09:50 AM | #7 |
Drives: 2010 Camaro 2SS Join Date: May 2011
I have seen cars hit by lightning that were never the same after, with one failure after another.
Whipple,custom cam,CAI,Kooks,Pedders and PFADT 626RWHP 549TQ ..
01-11-2012, 09:51 AM | #8 |
What Ohten said. If it was a primary line such as 7200 volts or higher could have done some damage. A house service or duplex line to a light or something wouldn't do anything unless it had a break in one of the hot legs. I have worked at electric utility co for 25 years, taken many a line off vehicles, high voltage or not, not much damage usually.
Ordered 6/19/09 Black on Black 2 SS Delivery 10/14/09! Added CAI, Heritage Grill, DRL Plug and Play Harness
01-11-2012, 10:09 AM | #9 |
I have seen what a 13.2 (13,200 V) downed line can do to concrete,a car would not stand a chance.
01-11-2012, 03:27 PM | #10 |
Drives: Sold: 2011 2SS/RS Join Date: Dec 2010
The car will be fine. I think mythbusters did a special, or maybe it was Top Gear? where they put a guy in a Volkswagen and simulated very powerful lightning strikes on the vehicle. It was fine afterwards.
I'd be more worried about damage to the body or paint from the line physically falling on the car--they're quite heavy. |
01-11-2012, 03:40 PM | #11 | |
VW was fine but the guy was fried
01-11-2012, 03:57 PM | #12 |
Drives: 2010 Camaro 2LT RS, 2009 GTR Join Date: May 2009
^^ It was Top Gear, he was scared but fine. The car should be fine, but have it checked anyways
Build thread: http://www.camaro5.com/forums/showthread.php?t=152335
Photos: www.flickr.com/bradbeer GTR Instagram: @NoCrustGTR |
01-11-2012, 04:16 PM | #13 |
Drives: CGM 2SS/RS, 1987 & 2014 Silverado Join Date: Oct 2010
Tires are not insulators, they are conductors so don't think they will save your life. Go here for more electrical myths. http://www.rge.com/UsageAndSafety/el...fetymyths.html
01-11-2012, 04:24 PM | #14 |
Similar Threads | ||||
Installation Camaro Needed for Manual for a Justice Install Package in SF Bay Area | Info@PeddersUSA.com | USA - California | 6 | 04-30-2010 08:02 PM |
Drag Racing Suspension Kits | Info@PeddersUSA.com | Suspension / Chassis / Brakes | 25 | 02-21-2010 08:48 PM |
GM memo to dealers | Moose | 5th Gen Camaro SS LS LT General Discussions | 41 | 02-04-2010 07:33 PM |
Ambient lighting (ABL) - the FINAL update = LIMITED TO DOOR PANELS | CamaroScotty | 5th Gen Camaro SS LS LT General Discussions | 338 | 04-15-2009 05:33 PM |
