04-02-2012, 11:41 AM | #1 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
ZL1 Fuel Pump Install
Installed the ZL1 fuel pump yesterday. Man, what a job that was, 4 hours. Had to take off the rear tires, tunnel support, exhaust, 2 shields and drive shaft. Then took out the front bolts of the rear and loosened the 2 rear bolts and lowered the rear. Took off the fuel tank straps and lowered the tank to disconnect all lines and electric connections. I bought the tool($54) to take off the ring holding the pump in the tank, so that was the easy part. Installing the pump was also easy with the tool. Tomorrow it's going to the tuner to get 72# injectors put in and a dyno tune. Will I ever stop doing this stuff.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
04-03-2012, 12:12 PM | #2 |
Nope! Your addicted to mods just like the rest of us mod junkies.
BBK LT Headers, Injen CAI, PYPES cat back, Trifecta Tune, Mike Norris Catch Can, Whiteline sways, end links and subframe bushings |
04-08-2012, 05:12 AM | #3 |
NJ/SoCal HT5 COTW 3/25/12
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71 Join Date: Nov 2011
So that's the only way to install the pump, I assume?
04-08-2012, 11:14 AM | #4 |
You assume correct.
04-09-2012, 07:11 PM | #5 |
Drives: 2011 Camaro LS Join Date: Sep 2008
What is the benifit of installing the ZL1 pump into a non ZL1?
04-09-2012, 07:43 PM | #6 | |
04-11-2012, 06:09 PM | #7 |
Drives: 2010 Camaro 1SS/RS RJT Join Date: Jan 2010
I just had one put on too
2010 Camaro SS LS3 Holley Hi-Ram Manifold,Custom grind boost cam,Vortech V-3,10Rib 3.47 Pully Airfilter Pipe Delete, 10 PSI, TSP LT Headers, Flowmaster Outlaws, Alky Control Meth Kit, PFADT 1.25, ZL1 Fuel Pump, DSS 1000HP axles, Mantic ER2 Clutch, Full BMR rear suspension drag pack upgrade. C6 Vette 18 rims with M/T 305 out back. COPO Hood
Race Proven Motorsports tuned |
05-22-2012, 06:42 PM | #8 |
Was this in your driveway or on a lift?
05-23-2012, 10:51 AM | #9 |
In garage with jack stands.
06-05-2012, 08:27 AM | #10 |
ZL1 CRT 1 of 53
Drives: 2012 & 2017 ZL1's Join Date: Jul 2010
I finally got my ZL1 fuel pump! It took forever to come in.
08-24-2012, 03:46 PM | #11 |
Drives: 2010 Camaro 2SS/RS,LS3 Join Date: Oct 2010
Can you please share the tool # and where can I get it?
LS-3, ProCharger D1SC 665. rwhp /562. rwtq @ 9.3 psi |
08-25-2012, 12:24 AM | #12 |
Drives: 2011 1SS/RS L99 Join Date: Aug 2011
You can get the lock ring tool here...
http://www.amazon.com/OTC-6599-Unive.../dp/B000F5LJ7S
2011 1SS/RS L99 VR - - Livernois 2c-hl cam, Livernois stage 2 heads, ported intake, ported TB, CAI intake, ADM scoop, Stainless Works 1-7/8" headers w/ hfc, Magnaflow 3" exhaust. - - 451 rwhp/411 rwtq - - |
08-26-2012, 11:38 AM | #13 | |
08-26-2012, 12:01 PM | #14 |
I have my ZL1 fuel pump in my garage with a 3" pulley for my Edelbrock with new injectors. I was going to put them in this summer but I think I'm going to wait and have it done this winter because I don't drive it in the winter. I'm thinking I should be around 550-575 RWHP. Now all I can think about is what to do next to get more power. Does it ever end???
Similar Threads | ||||
More Camaro ZL1 info!!! | MS3DALE | Camaro ZL1 Forum - ZL1 Specific Topics | 94 | 06-24-2012 09:44 AM |
NEW Official Details on Camaro ZL1 -- 580hp / 556 lb-ft torque!! | DarthNacho08 | Camaro ZL1 Forum - ZL1 Specific Topics | 420 | 09-27-2011 04:17 PM |
MSD Fuel Pump Booster - BRAND NEW CHEAP!! | Meister@Torq | Forced Induction | 1 | 07-25-2011 08:10 AM |
Stock Injectors vs Magnuson Kit Injectors | Mark-HD | Forced Induction - V8 | 24 | 01-27-2010 08:04 PM |
Camaro ls3 news...true or false? | Dark Knight | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 74 | 06-05-2008 05:29 PM |
