10-07-2014, 03:11 PM | #1 |
Drives: 2011 Camaro 2SS RS SIM Join Date: Aug 2014
Headlight HID Bulb
Hey guys, so my driver side bulb went out yesterday and I went to the dealer to get a new bulb went to install it and it does not have the same color as the stock one....anyone know whats the problem? (first bulb is the new one second one is stock)
10-07-2014, 03:36 PM | #2 |
Drives: 2013 Camaro 2SS/RS BRM LS3 Join Date: Jan 2013
You should replace them both if you want them to look the same. They degrade in performance over time.
10-07-2014, 05:59 PM | #3 |
So its normal for it to look like this color new? I changed mine because the stock one went out...these bulbs are 200$ each not sure if i want to change the other one too.
10-07-2014, 06:15 PM | #4 |
Drives: 2010 Silver SS/RS LS3 Join Date: Nov 2011
get some from Diode Dynamics or another vendor. much cheaper than $200 a bulb
2010 Silver Ice Metallic Camaro SS/RS LS3
Mods...so far: resonator/muffler delete, tinted everything, '13 shift knob/boot, bowtie delete, PFADT sway bars, CAI intake, Hurst short shifter, JBA cat deletes, BMR trailing arms/outer bushings/steering rack bushing, Bo White ported TB. Rhino79 Dyno tuned...405 HP/399 TQ |
10-07-2014, 06:18 PM | #5 |
The stock one doesn't look stock . Did you buy it used ? If so someone changed them to a brighter bulb .
