01-20-2012, 07:25 PM | #1 |
Drives: 2011 2SS SGM Camaro Join Date: Aug 2011
BMR 1.4" Lowering springs
Anyone have these and do you like? Also is 1.4in to low with factory tires and rims?
01-23-2012, 09:12 AM | #2 |
Drives: Race Car Join Date: Sep 2009
Here is a picture of one of our BMR customers running 1.4" springs with stock size wheels. I also have quite a few picture of other springs if you are interested in seeing them.
06-05-2012, 09:01 PM | #3 |
Drives: 2011 Camaro SS Join Date: Jun 2011
06-05-2012, 09:03 PM | #4 |
it's mind bottling..
Drives: SGM Join Date: Apr 2011
Di these effect any thing ? I've heard lower than 1.2 effects the dampers or soemthing
06-06-2012, 10:01 AM | #5 |
Drives: 2011 Camaro 2SS L99 Join Date: Jun 2011
I have them installed and my car rides great. I am really happy with the end result in terms of look. I couldnt imagine going with less of a drop.
2011 Camaro 2SS L99 A6
Rotofab CAI w/ race scoop TSP Long tube headers w/ high flow cats and full x-pipe GMPP axle back exhaust system Custom Dyno tune by ARD (Advanced Racing Dynamics) BMR 1.4" Springs all four corners "There is no replacement for displacement" |
06-06-2012, 11:16 AM | #6 |
Here are a couple more pictures.
06-06-2012, 11:23 AM | #7 |
We designed the 1.4" lowering springs to be as low as you can go without having issues. They were designed to be able to use the factory struts/shocks and also be able to use the factory hardware to be able to get the alignment specs. If you want to go any lower than this we recommend using coil-overs.
06-06-2012, 04:43 PM | #8 |
When you do the springs go ahead and by the strut bars and trailing arms at the same time. I wish I would have done these at the same time as well. Now I have to get back under the car again. It will be worth it though.
Suspension is addicting but I think the best thing you can do to these cars. Dropping your car will turn heads.
Similar Threads | ||||
Pfadt Race Engineering Lowering Springs Improve Looks And Performance. | Apex Motorsports | Suspension / Chassis / Brakes | 341 | 02-02-2014 11:52 AM |
Pfadt Lowering Springs for your V6 Camaro - Now availabe at Torq! | Erik@Torq | Suspension / Chassis / Brakes | 5 | 05-27-2013 11:47 AM |
Lowering springs: 1" or 1.4"? | SamSS | Suspension / Brakes / Chassis | 13 | 10-04-2011 08:29 AM |
FS -- BMR 1.4" Drop Springs -- V8 ONLY! | fgraciano1980 | Suspension / Chassis / Brakes | 18 | 07-30-2011 03:08 AM |
Any help? BMR lowering springs 1" all around, 1.4" all around or 1.4"/1.0" ? | SUX2BU | Suspension / Brakes / Chassis | 11 | 01-14-2011 05:18 AM |
