Old 01-23-2017, 05:39 PM   #1
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
Methanol Fuel Cell options / Methanol on E85 and more...
Hi dudes!
I'm running an Alky Control Methanol system on my Twin Turbo ZL1 and the kit was originally installed when the car had the factory blower on it.
So two questions...
1) What methanol fuel cell are you guys running? I have the ProMeth tank (the one that goes in the left corner of the trunk. It has been ok, but it just isn't a road race ready or very durable unit. It is injection molded and held down by two bolts and prone to cracking and lots of sloshing. Who has a JAZ or something else?
2) Who is running Methanol on top of E85? For the experts out there, if my car was always going to be running E85 should I think about off-loading my Methanol kit? Obviously, a retune is in order if I went this route. My motor is fully built...should I be able to make the exact same power? My car has never been dyno'd or run as a Twin Turbo car without Methanol.
Seeking INFORMED opinions.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 01-23-2017, 05:56 PM   #2
blake-b
blake-b's Avatar
Drives: 2009 ZR1
1) I've used and will still use the 4 gallon tank Julio sells. I had to fashion an aluminum strap to hold it in place. I've had no issues with it. I can't remember the brand name but it was one i'd heard of.
My install (trunkwise) is just like this one, tank and all with the exception of I mounted my meth pump at the rear of the battery well.
2) I'll be running meth with E85 but still not put together yet. Not sure if mine will be tuned to take any advantage of any additional cooling (if any exists) but more likely just there for a little bit of safety in keeping the IATs down. Guys on yellowbullet see gains with E85 and 100% meth. Besides, it is already in place.
3) If you haven't, look up injecting meth pre-turbos... I just opened a can of worms.
Old 01-23-2017, 07:41 PM   #3
Unreal
Drives: 2006 Z06
I run both. Every 1000+hp LS I know runs both.
Nick
Corvette Z06 -1200ish rwhp
Old 01-23-2017, 08:40 PM   #4
Sakudog
Sakudog's Avatar
Yeah, it is like a safety blanket. Just a bit of a PITA to fill and every 12 - 14 months rebuild the pump. I guess @ this power level I shouldn't complain.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Old 01-23-2017, 08:48 PM   #5
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
Keep the meth. E85 runs cooler (in the engine and the IVT) - it does nothing for IAT which can pull timing when in higher boost.
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 01-23-2017, 09:16 PM   #6
Unreal
Drives: 2006 Z06
Never considered it a pain to fill. Top off tank every oil change, no big deal. Beyond simple and easy.
I ran my first pump for ~4 years. Swapped it out with no issues.
Nick
Old 01-24-2017, 10:33 AM   #7
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Well gents, my tuner said I didn't need both so I converted my AIS meth tank to a supercharger chiller and got rid of the POS cooler that came with the Maggie. Now I circulate a higher flow of water through the supercharger during normal use and when I go to the track I pack the tank with ice then drain it back down when I am finished with the run.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 01-24-2017, 01:11 PM   #8
Sakudog
Sakudog's Avatar
AIS is now ProMeth and it seems like everyone is running that tank, including me.
Unreal, it seems like you are always on the good side of the Bell curve on things. My Alky control pump started leaking at 14 months and RedlineViper had the same experience. Julio @ Alky control said every 12-16 months, pumps need a rebuild.
Thanks for the input guys!
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Old 01-24-2017, 01:22 PM   #9
mrimpala02
Drives: Black 2SS RS w/White Stripes
Unreal is seems like you are always on the good side of the Bell curve on things. My Alky control pump started leaking at 14 months and RedlineViper had the same experience. Julio @ Alky control said every 12-16 months, pumps need a rebuild.
Thanks for the input guys.
Good to know. I have had mine for almost 3 years and no leak yet and has recently been relocated to the trunk near the battery. I am using a custom setup with a generic 2.5 gallon tank and LED light above to see into the tank at night.
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods |
Installed by Me & Tuned by Pat G
mrimpala02 is offline   Reply With Quote
Old 01-24-2017, 01:23 PM   #10
Unreal
Drives: 2006 Z06
I know what he says, just saying I never had issues, and only did it "just because". Old one still sitting in garage and I need to mail it back.
At least rebuilds are cheap/easy/quick.
Nick
Old 01-24-2017, 01:37 PM   #11
Sakudog
Sakudog's Avatar
Totally understand!
When I talked with ProMeth they recommended using mini-whiffle balls inside the tank (because methanol won't melt them) to stop slosh when road racing etc.
Have you seen a better solution?
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Old 01-24-2017, 02:24 PM   #12
Unreal
Drives: 2006 Z06
Never used anything but washer tank that has none of those issues. Its super tall/long with pickup at bottom.
Nick
Old 01-24-2017, 03:21 PM   #13
BiggFoot
BiggFoot's Avatar
[QUOTE=Sakudog;9522363]AIS is now ProMeth and it seems like everyone is running that tank, including me.
If you are going to keep the meth injection then you should get a spare meth pump to swap out every year so the one that was in use can get serviced by Julio. I happen to have an Alky Control pump I am not using that I would sell.
Blower Cam
RPM Level VII
TR6060
Old 01-24-2017, 04:23 PM   #14
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
What wheels are those?
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
