03-12-2023, 09:06 AM | #1 |
Drives: Chevy Camaro SS convertible 2012 Join Date: Jul 2020
RPK5-GM4101 wire connections in 2013 Camaro
I have a Mylink radio from 2013 now which I have changed to new radio. But I can't get the reversing camera to work. I have plugged the included cable into the new radio but nothing happens when I put it in reverse. But have seen that there is a cable on the new radio that says reverse camera wire!
Does it need to be connected as well and where should it be connected? |
03-13-2023, 04:22 PM | #2 |
Drives: 2013 Chevy Camaro 1LT Join Date: May 2022
Look for a wire from the harness that's the same color. It provides the power to the camera when you put out in reverse...
03-14-2023, 10:16 AM | #3 |
I tried it but it didn't work. I contacted support and they said since it's a manual gearbox I need to connect it to the cable that goes to the tail lights. How can I find it?
03-14-2023, 10:26 AM | #4 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Wiring diagram
03-14-2023, 12:58 PM | #5 | |
Drives: 2011 2SS/RS Join Date: Feb 2016
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
03-14-2023, 03:30 PM | #6 | |
I contacted support and they said since it's a manual gearbox I need to connect it to the cable that goes to the tail lights. How can I find it? |
03-14-2023, 03:33 PM | #7 |
Are you needing the back up light wire on the car or the trigger wire on the radio?
03-15-2023, 01:48 PM | #8 |
Drives: 2011 Inferno Orange Camaro 2SS/RS Join Date: Nov 2011
Since its a manual gearbox you can pick it up underneath on the side of the transmission.
You could also run to the Drivers rear tail light and pick up the reverse wire in there. The radio is looking for 12 volts on the camera wire to switch the screen to Reverse Camera Mode. |
03-15-2023, 02:10 PM | #9 |
Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
just get urself an idatalink maestro rr2 or if u want programmable outputs an rr3, done. all factory options working.
03-15-2023, 02:33 PM | #10 |
nm, just noticed the headunit ur using.
03-18-2023, 03:48 AM | #11 | |
Do you know what color the cable is on the side of the transmission? Thanks |
